Frame I.D
Can anyone help me with this frame number that I found on my truck thanks hop
Re: Frame I.D
What year truck?
Top of the frame drivers side? O =Oakland 1 all serial numbers started with a 1. 13,146th truck built on the assembly line. |
Re: Frame I.D
Re: Frame I.D
Does the cab have two holes for the dual master cylinder for the brake and hydraulic clutch or a single for the master? Quick way to determine a 63 cab.
Re: Frame I.D
1965-66 chevy first digit is C or K for 2wd or 4wd, then 14,15,or 25 for 1/2 ton swb, 1/2 ton lwb, or 3/4 ton lwb, next is 4 for truck, then 5 or 6 for year, etc. 1960-66 GMC begins blank = 2wd, I = inline 6 cylinder engine, or k for 4wd, next 10 for 1/2 ton, or 15 for 3/4 ton. Then 01 for swb or 02 for lwb. etc. Yours doesn't seem to fit any of these. Hopefully someone can give you more info. Good luck. |
Re: Frame I.D
Re: Frame I.D
If it has the x frame its a 1962
