restored short bed frame together or separate
Offering up a restored 1969 cab. This is the beginnings of a show truck or a super solid driver. Take a rusty cab and you'll have more in labor to get it to this point...
Auto low hump cab without A/C. Cab was media blasted to bare metal and then epoxy primed. This was a very solid cab as seen in the bare metal picture. Any minor Rust was cut out and replaced at a body shop. The bottom has been lizard skin lined. Firewall is painted satin black. Clean title with vin plate attached still. Doors were blasted and minor rust at bottoms repaired. Final body work needed on doors and cab but they're rust free solid metal. Cab is sold and picked up as of Saturday 10/14/17 Frame is the matching short bed frame (correct vin). It was blasted and finished with gloss POR15. Crossmember, and control and trailing arms were powdercoated to match. 73-up complete crossmember was added with drop spindles and springs. 4/5 drop. 12 bolt 5 lug rear. 15x8 Rally wheels restored with good tires 275/60/15. Power steering gearbox installed. Urethane bushings installed including cab mounts. Asking 800 for the pair of rust free doors. Will sell Frame with wheels/tires and power steering gearbox for 1,800 . Also have a solid GM 67-68 core support that was blasted and primered (220) that's available.... |
Re: Rust free restored cab and short bed frame together or separate
Cab in primer.
Firewall
Have a lot more pictures if interested.
I'm interested in the cab. I will attempt to private message you.
Ttt
Nice cab Jonathan, and great price.
POP |
3 Attachment(s)
Frame pictures as of 10/14/17
