Rig pulling to right when braking
Our 87 V20 Suburban pulls to the right when braking. Pretty much everything is new. New all spring 4" lift,shocks,steering arm,brake calipers,pads,rotors,draglink and steering box. Tierod ends will be here tuesday. Was doing it before we put the calipers on. Thought that would solve it. Maybe the brakeline is clogged?
Re: Rig pulling to right when braking
could be deteriorated rubber brake line..have you tried bleeding the brakes to check for fluid flow? ...could be bad caliper
Deteriorated brake line is probably correct. Change the hoses both sides bleed brakes and I'll bet problem solved.
I've also seen twisted rubber brakelines...rolling the caliper over without realizing it...a kink or twist will hinder fluid movement
10 to 1 it is a bad rubber line, if one is bad, the rest are not far behind, change then all.
There is also a fundamental design characteristic that causes the K/V trucks to go to the right during braking: the fore/aft steering drag link is trying to be compressed by the front axle windup. Since it can't be compressed it physically inputs a RH turn into the knuckle or, conversely, can also roll the steering wheel to the left. This is common on Blazers (shorter wheelbase makes them less stable and makes the phenomenon more obvious) and with 2 leaf front springs. Adding 3 leaf front springs (or a traction bar) to minimize axle windup helps the situation.
If you exhaust all of your brake options I would look at that next. K |
Randy |
I experienced similar braking on 72 C10 I purchased in 2014. Searched and found that flex (rubber) brake hoses fail internally. They actually close up internally over time not allowing proper fluid flow to defective side. It pulled very hard right, so left side was bad. Replaced both. Same thing happened on the 74 C10 purchased in 2015. PO had replaced left but not right. Had slight pull to left. Replaced right side. worked great, no more pull.
This may not be your problem. Wanted to pass on my experience. |
Had the same issue on a new 1986 truck I bought in 86. Pulled to the right took it back to dealer got it back pulled hard to the left now truck was worse. They had it back in shop a few time finally they replaced every braking component on the truck (less the steel lines ) and that finally fixed it. After a couple of years the truck started to have real bad break fade never did figure that out so I traded it off. Bought a 1989.
So we seemed to have fixed the problem for the most part. Still pulls a little but not bad. But we have been chasing loose steering. Like I said it has about new everything. But the lift has only been on about a 2 months. Well finally figured out the front driverside ubolts loosened and let the spring center pin loosen. SO the axle was moving back and forth about 2"! Tightened everything down and it is fine now. The rig belongs to my son and I told him to re torque everything after a couple weeks of driving it 100miles a day to work. Well he didn't. Doah.
Often once the customer is sensitized you have to have a "total kill" (and then some) for them to be happy. K |
