Brother's remote hood latch?
I'm wondering if any of you guys have tried the Brother's remote hood latch and if it works.
http://www.brotherstrucks.com/71-72-...tinfo/HLAC072/ My big concern is that when I pull my stock hood latch I still have to lift up on the hood. So how would that work if the remote is in the cab? |
Re: Brother's remote hood latch?
I would assume these work like modern hood latches: pull the cable inside the cab (unlocking the latch) and then push the handle under the hood, opening the hood.
I wouldn't mind having one myself! So, has anyone tried this? |
And why is it only good for 71 an 72? (according to the posted listing link)
Is the hood release that different on 69 and 70 models from 71/72? I could understand that the 67-68 hood release might be different or not fit with the hand brake mount. |
On sale until the 31st.....tempting.
I guess the hand release lever comes out to a different location to fit each specific grill. |
I did the version at the bottom half of the link below. I bought the cables for about $5 each at the junkyard.
Works like a charm. http://67-72chevytrucks.com/vboard/s...d.php?t=458433 |
Bummer,,, I was hoping someone had used this product before and I could get a review. I don't think I want to be the test subject on this one.
Somebody has to be the first to buy it in order to be the first to review it. I am thinking about it.
Well I placed an order on halloween for the 69-70 model and it's backordered (indefinitely?).
Will advise if it ever shows up. |
I ordered and received a latch for a 1972 Chevy from Brothers. Hoping to have it installed in the next couple of weeks and will post pictures. with a review.
subscribed
I bought one, just have not installed it yet. Yeah, I know...Useless. Sorry.
Here are some do it your self posts.
If like me you like a good challenge.:chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=458433 |
I bought one from Brothers as well. Came with an instruction sheet with LMC truck on the top of it. I am assuming LMC is the one actually making these or having them made as they were on the LMC website first.
LMC? Yikes!
I bought one off LMC because I was running billet inserts on the grille for my 68. I thought it was garbage, the pull latch was weak and broke on me. I ended up having to use vice grips for a while to pull on the cable. It worked but again the pull latch was weak, I got tired of dealing with it and didn’t want to mock something up on my own and ended up taking the billet inserts out so I could pop the hood the regular way. Just my experience with it
I just installed the LMC unit and it took some fiddling with the hood pin that goes into the latch to get it to release properly. I am concerned that the cable seems a little thin and not robust enough but hopefully it lasts a while.
The latch portion is fine though. This also forced me to adjust the hood so it pops up when the latch is released and it works great now! |
As others have posted. I installed it and it felt like it was going to break. It took one person to push down on the hood, with another in the cab pulling the release without breaking anything. Off it came and I'll put the original back on. I don't need to cruise with a buddy just to open the hood. Pure garbage.
some one will buy it put a better steel mesh cable on it and it will work fine.Its like any thing We as the guys that use it seen to be the ones that fix it and update it.Then LMC or other sellers will follow and steel the fix.
