4wd front spring hangars
These are clean, not rusty, pitted or greasy, $150 shipped for the fronts.
$100 shipped for the rears. |
Re: 4wd front spring hangars
Pics of rear hangar mounts.
ttt
maybe interested in the rears do you have pictures
Looking for the rear horns for a 4x4 frame after the rear ended spring hangers |
I removed the rear spring hangars from that frame.
The other rail has a dent at the end of the top rail, can see it in the picture. Both sides had a hitch welded to the upper part as seen in the picture too. |
How long do you want the frame rails?
I would remove the rear crossmember for packaging, $65 for the frame cuts with the crossmember, shipping I think would be around $30. |
I think that should work
I need them about where that bend is about 3 to 4 inches to the left of measuring tape to the very end
Would you be willing to cut the drivers side frame rail behind the front cab mount if I took the fronts?
The frame is already cut behind the front cab mounts and separated from the front crossmember. I will post a pic of it.... |
Frame rails
I will send you a PM randy500.
Ttt
Spring mounts still available
Are the shackle mounts for front leaf springs hangers still available? The second photo you posted.
Not sure but did you sell the rear cross member to Krex.
Or do you have another? If so you can ship with the engine cross member I said I will take on hour other thread. Thanks Chris |
