Need help identifying this power steering conversion
5 Attachment(s)
So i need a little help here because i haven't seen one like this before. All of the power steering conversions i've ran across require the steering shaft to be shortened, but yet mine isn't. The steering box setup is about the only thing i haven't changed since i picked up the truck and i'm kind of at a loss. You can see how low the box sits in the front and i actually get occasional sway bar contact with it. The drag link is perfectly level and completely centered....it is extremely close to the engine crossmember but doesn't contact anywhere in travel. No problems with alignment, driving etc..etc..etc...Just wondering if any of you guys recognize the conversion bracket & frame stiffener used and can maybe shine some light on what pitman arm was used and if this box is indeed one for a 74-87 truck. Thanks.
Re: Need help identifying this power steering conversion
Continued
There should be numbers cast into the box, those will tell you. Also how high off the top of the POL tubular lower a-arms are sway bars mounted? Nothing in the steering mechanisms hit? So it it looks good to me, I've seen them on eBay but I personally don't know who made the plates.
Also I believe the 74-87 boxes used o-ring fittings in the fittings at the box instead of flare, you might check there and that will tell you something. |
Do you have the stand-offs installed on the frame for the sway bar?
There is no way to properly upgrade to power steering without shortening the original steering column shaft. That steering box adapter plate kit is what is sold by everyone except me. They do not keep the steering box in line with the steering column.....I don't know why. I make my own that keeps the steering box in line with the steering column.
