49 5-Window Cab - Inner Panel Rust - Fix or Replace?
Not the best picture, but what I have atm. The inner panel to the center rear window is really badly rusted almost all around the center window. Once it was blasted it definitely came out pretty bad. Does the center section remove from the inner sides that fit the corner windows?
https://farm5.staticflickr.com/4552/...674fa5_o_d.jpg Best example pic of the inner 5 window panel (not mine)....it looks like the center section would separate and I could replace just that? http://st.lowrider.com/uploads/sites...6-1024x680.jpg Is it easier to replace this or weld in patch pieces? Its rusted out right around the crease/bend around the center window. |
Re: 49 5-Window Cab - Inner Panel Rust - Fix or Replace?
Also, have a build thread here.... http://67-72chevytrucks.com/vboard/s...d.php?t=735623
get some better pics of the area your talking about...I'm not seeing what your describing. ..I think I see it but the pic is dark...
I see at minimum a outer and inner panel replacement if you don't want that rust popping through is 2 years or less, when you open it up your find more than one nest of cloths and paper no doubt. |
It's dark out there... flash and black paint make it hard on the pictures... maybe this is a bit better....
So, look at the top edge of the center window.... its completely rusted out from most of the top section.... The bottom of the center window isn't too bad... but the flat part that is about where the belt of the cab is in pretty poor condition. If that flat belt part can be hidden behind seats or something I'd be ok with it. It looks way to bad to cover up well with filler... but maybe inside a cab it's not going to get as weathered as the outside paint and cramming a bunch of filler is ok-ish? If its going to be visible, I want something thats gonna last. https://farm5.staticflickr.com/4581/...e2c928_k_d.jpg https://farm5.staticflickr.com/4544/...c7505c_k_d.jpg |
Here is a pic of the outside cab after being blasted... still some w&g remover that hasn't flashed off yet.. but should give decent condition of the outside on this area. Who knows what it looks like on the inside between the inner and outer skin.. Obviously the inner is toast.
https://farm5.staticflickr.com/4549/...8881ab_b_d.jpg |
the seams are spot welded on the inside and the three pieces are put in as a unit. From what I see on the outside you have a problem with the back lower panel and the upper window outer panel.
The inside thou, after being blasted just looked so rough... sounds too difficult to sep the seam of the center section if it's spot welded on the back.... I can't even find someone that sells just the sheet metal for the center... all of them include the side windows... |
2 Attachment(s)
You can't swap out the center because it's welded with a "pinch weld" to the side pieces. Swapping the whole thing is really pretty easy. It's spot welded around the windows and down the B pillar under the windlace holder. There are a few beads on the vertical support that goes down to the floor from below the rear window. It really is pretty damn easy to do.
Here is a photo of the whole thing I took out for mine and I went out in the rain in my pajamas to get you this photo of the back side so you can see how the center section is pinch welded to the side pieces. Brian |
Brian |
Yea, just gonna suck it up and take the whole inner piece out.... was looking for a better way and looks like that isn't happening... On the bright side, those two dents on the outside top/rear are gonna be a lot easier to hammer out now! |
But get the patches on the bottom done and the structure repaired before you cut it up any more.
Brian |
You want to do a "dance" with them all. Put the doors on, change the patches on the bottom, that is way more structural shape changing than the inner panel is. You can remove that (it's out of my cab right now) without making a big deal, the patches and structure of the lower cab is a different story, you want that right first.
Brian |
Are there spot welds? not sure what to cut Thanks Mark |
