Any pics of how you ran your air lines up front
hey guys im trying to finish up the front bags on my truck. anyone have any pics on how they ran their airlines to the front bags? thanks
Re: Any pics of how you ran your air lines up front
How did you bag the front? Is it bags on a stock cross member? Aftermarket crossmember? If on a stock crossmember, I usually drill a hole in the back of the spring pocket, put a grommet, and run the line out that way. Then just follow along the frame from there, to your valves.
yeah its on a stock crossmember. You run it over the shock?
^^Did mine almost the same way. The only thing I did different was I ran my air lines on the out side of the frame. I was trying to get them as far away from any heat as possible.
thanks fellas. finally making some progress on my truck
I ran my lines close to the same way and so far having good luck.
