WTB Single Wall Top Tinted Side Glass
I am looking for a factory piece of single wall top side glass for the passenger side. Not sure if both sides are the same? Glass needs to have factory tint, if I can't find just one piece I would consider buying the set to have a spare.
Re: WTB Single Wall Top Tinted Side Glass
I’m pretty sure the glass is the same in the double wall just a different gasket.
I've got both loose and the 1x wall glass is thinner - it's really thin - and GM lists differing part numbers. The glass guy I know says the thickness difference shouldn't matter and he thinks he could use 2x wall glass in my single wall top. I've chased tinted 1x wall glass unsuccessfully and may use the double wall glass......or the sliders :)
Andrew, I use to have an extra single wall glass from a parts top I bought in Hickory. I think I may have broke it when we moved. I'll do some checking. |
I looked last night I do have some double wall tinted glass I just need to make sure I have enough for my projects should know this weekend.
So I checked and I do have 2 pcs of sof-ray glass double wall glass I can spare 50 ea. plus shippng if interested.
Doesn’t look tinted but here is single wall top glass just posted.
http://67-72chevytrucks.com/vboard/s...d.php?t=754110 |
I have a whole set of tinted glass that came with my Blazer that I'm not going to use. How do I tell if its from a double wall or single wall? Do you have a measurement of the thickness of what you need?
Thanks for the update Graham57a. I need the glass too, I'm hoping they can help.
Jeff |
2 Attachment(s)
So has anyone figured out how thick the single wall glass is supposed to be? This is what I have, its less than 1/4", but the same as the door windows in my truck.
Just a follow up on ECS, they said they do not have a way to make the blazer top glass. They did say they would be able to date stamp a piece of glass if it was sent to them but would need a factory piece to match. Sounds like a pain, I'll just hold out for a factory piece haha
Good to know, thank you so much for the intel.
I have 1 piece of single wall tinted glass. It's a factory "Soft-Ray" piece. It's the thinner glass. Not sure how I would ship it though?
Let me know if you have any shipping ideas
