Big Dilemma VIN # CS181F
The guy i bought it from told me today it was originally a 2wd now i am thinking possibly a 71 model the front has 6 lug with the transfer case installed . the rear has the original 5 lug ! is there Anyone that can decode this ? there is confusion amongst decoding site blogs that had already been posted ! any help would be greatly appreciated added a pic of Door tag with Vin .. dont see any site with production numbers for the 8 maybe its a GMC .. it does have coil springs in rear still so 2wd is a solid guess and the frame stamp under hood matches the vin Help !
Re: Big Dilemma VIN # CS181F
2 Attachment(s)
I have a 72 4X4 Blazer, I compared the data plates and I would say yours is a 71 2X4 Six Cylinder Blazer made in Flint. Your weights are lower than mine so I would say the data plate represents a 2x4. Did Someone try to convert it to 4x4? If you had the info off the SPID on the glove box door that would help more.
Smitty |
1/2-Ton Commercial - Model C/Series 10 - 115-in. w.b MODEL BODY TYPE PRICE WEIGHT PROD.TOTAL CS10703 Chassis & Cab 2656 3090 1476 CS10734 Fleetside 6.5ft 2816 3506 32865 |
Smitty |
Smitty |
Post some pics... Smitty |
5 Attachment(s)
Smitty |
Good luck with the build. You can look at my build on Sloppy Jo to see what you are about to get into. Smitty |
