2000 silverado z-71 front axle options
i have a 2000 siverado and i was wondering if there is an aftermarket 1 piece axle shaft available for the right side 8.25. i have managed to shatter the slip collar. a couple hours at the junkyard i can harvest the parts but if it failed once it will fail again
im not worried about gas millage or the vibration associated with the modification. i can find parts all day long for the 9.25 http://www.dieselworldmag.com/wp-con...04-AXLE-07.jpg |
Re: 2000 silverado z-71 front axle options
I'm not sure about aftermarket, but you can use a shaft/half housing from an AWD truck(Denali or escalade). It will be one piece and it won't have an actuator.
brain fart on the awd didn't even think about it but thank you. i will keep my eye out at the junk yard. should be real cheap and easy to get.
https://dudazps6njn84.cloudfront.net..._id=880000500F |
