Dana 60 question
I've looked all over the World Wide Web and cannot find any answers on application of part numbers
Left hand steering knuckle cast number c41896 and c38138 , are these the same ? Will either fit 1990 gmc v3500 ? Thanx in advance :metal: |
Re: Dana 60 question
If it has 6 bolt spindles then yes. Ford used 5. GM and dodge are pretty much the same.
dodge = middle of knuckle for casting ear for tie rod. gm = lower area of knuckle for casting ear for tie rod. but yes they can swap otherwise . |
https://www.ebay.com/itm/CUCV-GM-Dan...xaQrXD&vxp=mtr
this is correct for your v3500 they do appear to be interchangeable. |
Price is good |
It fits. You're fine.
