Putting steering wheel lock plate back in - help
Anyone have any tricks for putting the steering wheel lock plate back in?
I pulled it apart to replace my ignition lock cylinder and now I am having a difficult time pushing the plate past the ridge to install the C clip/lock. That spring under it aint no joke or, I am losing my strength in with age! :sumo: |
Re: Putting steering wheel lock plate back in - help
I use one of these:
https://www.summitracing.com/parts/o...SABEgKIRfD_BwE They are sold at most parts stores. |
There is a tool that compresses the plate to install the ring. Without that tool, its a nightmare to fight.
There is one or 2 wide splines on the shaft that needs to match the teeth on the plate.
Yup, there is a master spline. You need the tool, it pulls up on the shaft along with pushing down the plate
Thanks everyone... I wrestled it last night for about 30 min and 2 beers (beer strength) and could not get it in far enough to set the clip. I will check with my local parts store for the tool. Figures there is a special too for EVERYTHING.
Thanks!!! |
Loan a tool from autozone. That’s what i did. Worked like a charm
I appreciate all the help!!! |
Done and done
Or make your own tool [IMG] [/IMG] http://bowtieguy.proboards.com/thread/1227/tilt-column-tear-repair-renew
