1962 Back half
3 Attachment(s)
Whatcha think ?
I don't know if i should put on the weld center caps And the disc brakes just barely fit |
Re: 1962 Back half
Very nice
Re: 1962 Back half
What kit did you use? I’d like to back half my 72
Re: 1962 Back half
Checkered racing Back half, and mosier 9 inch center section and axles
Re: 1962 Back half
If you don't wanna weld on end caps you can order end caps for Workout Equipment. It uses the normal 2x3 tube and just has a press-in black plastic end cap. I did that so I could access wiring that I ran through my frame tubes.
Re: 1962 Back half
Put the bed on, and went to remove my fat tires to install longer lug nuts, and couldn't get the tire off, because the bed is too low
Had to raise the back 3 inches to be able to remove the tires ha |
Re: 1962 Back half
Hahaha yea that'll happen. Mine does the same. Can't get the wheels off unless my jack is ALL the way up.
