Flex plate question
Trying to figure out why this was done to the flex plate.Came out of a 72 half ton with a 350/th350.
Re: Flex plate question
balance
Thanks harpo321.What I meant to say was how this was done to the flex plate.
The flexplate is spun on a balancer. There is a drill press set up on the balancer, the operator drills the flywheel/flexplate where the machine shows it is heavy.
Thanks for the info B.W. Kind of an odd shaped hole that's why I asked .
That kind of hole is caused by a dull or incorrectly sharpened drill
its easier to balance the outside of the flexplate than at the centre line of the crank, less material needs to be removed. they normally balance with a hand drill on the balance machine
Most drill bits will leave a triangular hole in thin metal. If you want them round, then that's where a reamer comes in for the finish
