Brake problem
I took my truck('65 C10) for it's second second shake down drive today. The first one, the brakes were not working right, they didn't feel like they had the power boost. So, today I checked to make sure the booster was getting vacuum and, it is. But the brakes definitely didn't have the power brake feel. The booster was installed new about 4 years ago, but the truck has sat since then. What is the next thing to check? Could I have got a bad booster?
Re: Brake problem
Start your tuck with your foot on the brake. If the pedal goes down when it starts, your booster is working.
Re: Brake problem
Check the check valve?
Re: Brake problem
Re: Brake problem
Thanks for the tip, I'll check it out. What am I looking for (I know what the check valve is)? When I pull it out from the booster. How do I test it? Edit: I did a Google search and found out how to test it. |
Re: Brake problem
Well, when I started the truck with my foot on the brake pedal, it didn't go down. Also, when I killed it with my foot on the pedal, it stayed up. When I pulled the check valve out of the booster, you could hear the hiss of air going into the booster so, apparently it's holding vacuum. But, the brakes aren't working like power brakes should. What could be wrong? I'm sitting here scratching my head wondering what's going on.
Re: Brake problem
Did you drill a hole in the brake pedal 1" lower than the factory non power brake hole? If not, you don't have the correct pedal leverage ratio and it will never feel right.
Re: Brake problem
Re: Brake problem
Re: Brake problem
Re: Brake problem
Been doing some research on brake issues and, I'm wondering if the push rod is not adjusted correctly. Anyone have brake issues because of this?
Re: Brake problem
We really need more info: disc or drum? split front-and-rear system, or original single system? what make and year master? make and year booster? Pics would help a lot. Using an equalizer-block between output lines from Master and remainder of system?
Given this extra info may enable us to hit the mark and help. Sam |
Re: Brake problem
Re: Brake problem
2 Attachment(s)
Here's pictures of master cylinder and brake booster. Can't see anything that says what brand these parts are.
Re: Brake problem
Man, I feel your pain. I'm fighting the same thing. Here's one of the best diags I've found which happens to be my parts too:
http://www.classicperform.com/TechBo...htm#rightvalve My mechanic says the travel (assuming the booster is ok) might be a brake not moving properly due to blockage, leak, stuck...yada. He suggested clamping the flex hose(s) to isolate which wheel. My rear only has one flex hose at the tee. And with posi trac, I can't rotate just one wheel. When I clamped that hose, I had little pedal travel. So, I'm thinking one of my cylinders is sticking. I noticed a difference in travel with shoe adjustment, but I don't think that's all. I might go ahead and replace them since they don't look as new as the rest and I can clean the lines out more. I hope this helps. Good luck and keep us posted |
Re: Brake problem
UPDATE: I replaced the rear brake cylinders last night and that helped a little but didn't really solve the problem.
wrt to the troubleshooting link I sent, I fail Test 1 of the booster test, but not the others. Any progress on yours? |
Re: Brake problem
Re: Brake problem
Is your booster a single or dual diaphram booster?
Re: Brake problem
Re: Brake problem
I'm wondering if it might be good, to move the master cylinder rod in the brake arm, back up to the original hole to gain leverage on the master cylinder, if nothing else improves brake function. Just a thought.
Re: Brake problem
Re: Brake problem
Brake problem
I have a problem with my rear brakes on a 1965 C30 panel. It has the stock rear end. When I bought it the RR brake was locking up. We did a complete brake job, replacing everything, front, rear and master cyl. The problem is, on both sides of the rear brakes, the shoes will not come together all the way. The top is spaced out about 1/8". It was that way when we took it apart too. The wheel cly's are new, from NAPA. It seems that the wheel cyl are not collapsing all the way. Are there different wheel cyl for this truck? The new ones are the same as the old ones.
Re: Brake problem
