Purchasing headlight adjustment screws???
Where in the world can I order all 8 new headlight adjustment screws for an 89 blazer?
Re: Purchasing headlight adjustment screws???
http://www.lmctruck.com/icatalog/CSB/full.aspx?page=195
Basic stuff, get the whole thing ---screw and plastic #7 |
Clicked on that part number hours ago and it's not available. |
Auto parts stores typically have a red help section w/ odd parts such as door hinge pins/bushings and probably the HL adj. screws you're looking for.
I found some/all the parts are Dorman, googled it for you... 42119? If that's what you want they're as close as a parts store. https://www.google.com/search?q=dorm...utf-8&oe=utf-8 |
I had them look up the part numbers about a week ago they were unable to order the proper ones
The ones on the shelf they did have fit blazer s10s |
have you tried here?
http://www.clipsandfasteners.com/Hea...lies-s/106.htm |
I believe this is what you need
http://www.clipsandfasteners.com/Hea...M-p/a11243.htm |
I think that is! Thanks for the links
I eliminated the plastic and used a nut and washer from behind.
