1987 V2500/3500 12v nv4500 build
5 Attachment(s)
So after searching long and hard for a rust free truck in Iowa...I finally bit the bullet and bought a 12v swapped V3500 in Washington! I had a good friend inspect it and buy it for me. It will be here in Waterloo IA in 6 days where I can finally completely inspect this (hopefully) fine machine and get to working on the modifications that I have in store.
Currently it has: Front frame section was boxed with 3/16" steel and custom motor mounts were made out of 1/4". Engine: 96 12 Valve Cummins •New Cylinder Head. With Hard Seats Ported and polished 60lb over valve springs ARP Head Studs OE Cummins Gasket • PDD 5x.014 Injectors • DPS 62/65/12 Turbo • #10 plate • 4K RPM Gov. Springs • 17.5* Timing • 4" Exhaust with 8" Stack • New Lift Pump • 1 Wire 136amp Alternator Transmission: NV4500 •Centerforce DFX Clutch •Single Mass Flywheel •New Hydraulics Upgraded: •Input Shaft •Main Shaft •Cluster Shaft •New 3rd Gear •5th Gear Nut •HD Synchros •All New Bearings Transfer Case and Axles GM NP205 Advance Adapter Kit to mate to Dodge NV4500 Front: Dana 44 with truss. 4:09 gears Rear: 14 Bolt Corp. 4:10 gears. Detroit Locker New driveshafts New brakes front and rear. 4" Lift Custom built rear leafs I plan on: Downsizing the injectors to 5x.012s Putting a normal 4" exhaust system on it with hushpower muffler Replacing the fenders and hood with new sheetmetal Restoring the interior Most likely installing Suburban buckets, overhead console, and center console Lowering it about an 1" and installing 35s Changing out the D44 with a D60 with the works Changing gearing to 3.73 and adding front and rear ARB AFC live Make a MUCH better trans crossmember My plan is to make an exciting daily driver that can also take off to Moab or Montana and have everything built to be "unbreakable" but most importantly reliable. Much more to come..! Id really appreciate any feedback/advice as this is my first complete build |
Re: 1987 V2500/3500 12v nv4500 build
Looks like a neat project with a lot of the hard work done....what part of WA did it come from? Is it in your possession yet?
Some parts are here and more ordered, so updates will follow. Posted via Mobile Device |
Nice buy! I like your plans for the truck. It should clean up pretty nice and make a sweet truck! Once you get the AFC live, you may not need to down size your injectors.
No, there is no really good kit for them. But, I can get you the mid section for a first gen dodge that will get you over the tcase. You can make the down pipe cheaper than buying one I'd almost bet. I'm betting you need one for an HX40 flange? I have used 2nd gen dodge, super duty, and even newer chevy diesel tail pipes. It really depends on how you want the tail pipe outlet to look.
Any recommendations for side exit that can fit between the leaf spring and the 31 gal suburban tank? |
Here's a suburban I did. I used a 4" kit from a 93 dodge and I had to modify the tail pipe to fit nicely.
http://www.67-72chevytrucks.com/vboa...t=v+rig&page=6 |
2 Attachment(s)
A bit of an update.
I got the 1st gen dodge exhaust in with some cutting and welding, but I have the tailpipe touching the corner of the suburban tank. Im thinking about putting in a heat shield with spacer on the corner to push it away, I assume thats enough? Diesel does vaporize like gasoline so I think Ill be OK. I put my new injectors in and installed the AFC live, but still cant get it to not smoke. I even turned the AFC live to the minimum and removed the pre boost screw to no avail. Then I learned that the PO adjusted the star wheel all the way forward and didnt install a longer spring! No wonder, theres no tension on the foot. So I have a TST spring on the way. I also braved the Pella tornado to get a rough Dana 60 from Dougs 4x4. I couldnt be happier, unless I actually got to see my first tornado! I also discovered why I have such a jerky throttle at low RPM. I only have a VERY stretched out throttle return spring. So that too is in the mail. My jerky throttle only happens when its warmed up so it might be a clogged fuel filter or possibly a bad OFV. I have a new fuel filter installed now and will have to see how the throttle return springs work before I get a new OFV. Has anyone used the torque motorsports 2009+ dodge 3500 brake conversion on the dana 60? It seems like a great idea, just wondering about opinions. http://www.torqmotorsports.com/Dana-60-Big-Brake-Brackets_p_263.html Up next will be a bit boring, check and set valve lash, install 35 spline stub shafts and ARB, high steer kit and custom ORD leafs. |
I also found out the "rebuilt" NV4500 sure as hell doesnt feel like its rebuilt. Ive been mulling over swapping into a 47RH, but then I dont think I can reuse my chevy NP205. Any thoughts/recommendations for swap vs rebuild?
Those tornadoes were crazy that day. You were only about 24 miles from where I lived. Next time you get over this way let me know. |
Yes it is a 32 spline figure 8 bolt pattern, thats why I want to keep it if at all possible.
I will hit you up next time, the silo across the highway from Dougs lost its roof. Pretty nuts! |
Coming along nicely there. I just finished rebuilding a front dana 60 for my truck too. Parts for those are expensive....I see its 4.56 gears so I guess you will be re-gearing it? I used SVL gears in mine, made by Dana, most ratios are about $150, they set up nicely and seemed to be good quality.
Since your going 35 spline outers...Dennys drivehsafts has the cheapest stubs at $85 each and right now 35 spline Yukon hubs are about $280 on amazon and there is a $30 rebate on them, pretty good deal. How is your 205 mated to the trans and is the trans chevy or dodge? I guess the chevy trans would be 32 spline output? I rebuilt my NV4500 because I had to switch from 2wd to 4wd, really I just changed the mainshaft and the input gear but it was very simple to work on. Didn't need any special tools either since the rear bearings are not pressed on the newer mainshafts. |
There are also 2 plastic bushings in the throttle linkage that wear out, if your bellcrank has a lot of play you should change the bushings, they are cheap and available from cummins.
It is heavy! And that means expensive Im finding out!
I want to go to 3.54 but I can only find 3.73 for both the D60 and 14B. Thanks for the heads up on Denny's, Ill definitely check them out. The NV4500 is Dodge and it uses an Advance Adapter kit to mate it to the NP205. I ordered the heavy and light throttle spring, both cummins parts, and hopefully that along with my AFC spring will control the smoke/fuel delivery. From my very preliminary assessment, these are the only things that are missing/worn out. |
Dennys Driveshafts also has the cheapest dana U joints and should have the gears too along with free shipping over $99. They also have the cheapest king pin rebuild parts, get the part numbers from the dana 60 bella vista article on Pirate 4x4.
I got my front rotors from Summit with free shipping, I looked up the raybestos part number from rockauto and then found it on Summit, I think the rotors were $37 each, summit had to special order them so it took about 2 weeks to get them. The long inner axle shaft is about $65 so I bought that new from dennys too. The short one I used a sleeve to repair the inner seal surface, those are about $25 from rock auto. If you need any part numbers on that stuff just ask. |
I had 3.73 and just changed to 3.54, my tires are 32.5" tall, I am happy enough with the change but it was better with the 3.73 gears. I'm running dana 70 rear from a first gen dodge, 65" wide which looks good on my 72 but would be a little narrow on a square body. The 14 bolt is much stronger and with your taller tires the 3.73 gears will be perfect.
I appreciate it Randy, but I think Im going with 14" rotors and 2 piston calipers from a ram 3500.
Im looking at Dennys now. |
the 2011 and up 2500 vans had a 10.5 rearend option that has 3.54 gears in them. they are an aam rearend thats the same as a 14bolt. I have a set in my 14bolt that I bought off ebay, guy had a bunch of factory takeouts. hes all out now. only way I can find them now is brand new from the dealer. haven't checked on price yet though.
Its been a long time since my last post. New girlfriend, new house, and new job has taken up most of my time. I got the truck relocated this winter in between snow and -43 windchill days and started tearing her down.
I removed most of the front end, except the bumper because it is welded to the frame. Then I pulled the pump and lines as well as the front cover and tappet cover to seal some leaks. Found out that my rear pump support has been broken for who knows how long so reassembly was on hold. I received a new OEM support and front crank seal because my crank snout was badly grooved. This last weekend I went to install everything and bump the timing back to 16 degrees, only to find that I lost the support!! I spent 3 hours cleaning my garage up and still couldn't find it anywhere! So i ordered another and am currently waiting. Once I get the pump in and secured and the engine buttoned up, it will be time to rework the radiator support and modify the AC bracket to move it above the Alt. I can imagine spending $600 to get one of the kits when a few beads and some plate steel will get my the same result. I took my inspiration from grw800 whose thread is located here: https://www.cumminsforum.com/forum/9...d-cummins.html Then it will be on to a new clutch and trans support....possibly a twin stick for the np205. Not to mention finally getting around to filling up the Dana 60. |
Many things have changed/progressed.
My dana 60 has new 3.73 gears, ARB locker, 35 spline shafts and paint job. I decided to order the complete rebuild kit from 4wd factory after disassembling the 30 year old axle. https://i.imgur.com/r5E4mbN.jpg Im currently waiting on the torque motorsport disk brake adapters to fit the MUCH larger dodge 3500 calipers, due to COVID-19, before I can put it all together https://i.imgur.com/v28Rro3.jpg I decided to part with my Nv4500 and NP205 and go with a 47re for convenience and (when built) longevity. I found a 98.0 harness and PCM for a couple hundred bucks and a 91 dodge NP205 with adapter and 23 spline coupler for a few more. Upon disassembly, the idler bearings and one shift collar are shot so I it will be getting a rebuild. Haven't locked down a trans, torque converter, flexplate yet, but plan on getting something cheap to use as a core for either a complete dynamic trans or get it built locally with Goerend components. @Dieselwrencher Do you have any IA trans rebuilders that you would recommend? |
A friend of mine, Chris Snyder was building them but IDK if he is currently or not. I'd also recommend getting an aunt eater from Firepunk to run the 47re. The stock PCM works but the shift points suck IMO. I have a local guy that builds trannys for me but I'm not sure on his warranty on the dodge diesel units etc. I'll find out.
Big Delay.
On my road trip to Montana/Washington in Aug my trusty 2001 4runner decided to puke all the oil out of the engine and ATF out of the trans after crossing the Rocky Mountains. She had 273k miles on her and I was hoping to keep it pretty much forever, but when all this happened 1,800 miles away from home I didnt even investigate what caused it, and decided to buy a new one. https://i.imgur.com/gmmMawM.jpeg Once I got to Montana, I found a holy grail of Junk Yards near Somers, MT. There were probably 100 various squarebodys, as well as almost anything cool you can think of! There were 2 fastback mustangs!! IN A JUNKYARD!! along with 1st gen Camaros, AD trucks, literally everything. These show very little of the yards and I apologize, my dad and I were too awestruck to properly document the experience. https://i.imgur.com/CofJy4s.jpg https://i.imgur.com/uYTIf9Z.jpg I also decided to get into ammo reloading around the same time. (horrible timing, I know!) This was my initial setup, but Ive gotten much deeper down this rabbit hole. https://i.imgur.com/SZ1goNb.jpeg Since I can now make my own ammo, why not buy something Ive always wanted!? So I also bought a Marlin .444 Dark series, .357 1894C, and Ruger GP100 in .357 because, it gets cold in Iowa, need an inside winter activity. As far as truck updates go, snagged a 97 47RE with TC for a decent price and dropped it off at Schmitt Performance Transmissions today. Chris seems like a great guy! I decided to go with Goerend everything, including billet input and their new AD torque converter (supposed to be the best of both worlds). Unfortunately, even though the 91 NP205 is 23 spline, it does not bolt up to the 47RE without cutting the trans output shaft or using a ORD adapter. So to preserve spline engagement and make, I got the ORD adapter ordered. I also bought a wabco air compressor and have it partially installed. https://i.imgur.com/4aXyNcQ.jpeg Ill need to massage the throttle linkage. With AMPLE room for a power steering pump!!:lol: https://i.imgur.com/ItxJ6TE.jpg I was very confused over all the connections locations for oil and coolant. Thanks to Jonesy at Adventure Vehicles NW, I understand how it all goes together. Here are some pictures if anyone is in the same position (way over their head!) https://i.imgur.com/YuN00ah.jpg https://i.imgur.com/GjfOKE7.jpg https://i.imgur.com/7vJv5r6.jpg And Ill be getting an oil feed line than adapts the vacuum oil feed to the air compressor, the return will flow into the gear train. When I was at Lowes a bit ago, came across this badass Cummins swap with about the best license plate Ive seen. https://i.imgur.com/R4HLUOx.jpeg |
Wow, that junk yard is awesome! I'd love to go there! Nice you got into reloading. You're probably not running around trying to stock up like the rest of us. :lol: Nice score on the air compressor. I kind of wish I put on eon my orange truck. Make sure you put the support bracket under it that bolts to the block other wise it will break the gear housing! The old chevy is pretty sweet!
Thanks DieselWrencher, the 100% duty cycle is definitely overkill for what I am going to be using it for, but rule #1 is to always look cool!:smoke:
That air compressor flows about 15.4CFM at 110psi, which I don't know about you guys, but I think that's pretty stout! Ill definitely install all support brackets when its spinning, just got to lift the engine up a bit so that I can share the rear support with the engine mount. I got my 47RE back from Schmitt Performance Transmission, with a full rebuild, billet input shaft, and Goerends valve body. I also bought the Goerends AD triple disk converter, its supposedly built with an Allison stator and is marketed as the "Best of both Worlds" in between the 15SS and 17SS. So we'll see how it goes. I welded up the flexplate stiffener, and of course the best weld was the last... https://i.imgur.com/BWasCS1.jpg I also got the trans to T-case adapter from ORD (but it looks like its the same as the Advance Adapters one). https://i.imgur.com/bf8sxrO.jpg I do have a question about transmission shift linkage on these swaps. Its not in the truck yet, but just something that Ive been thinking about. The truck still has the column shift column, but was converted to 5 speed before I got it. It appears that the column shifter on our trucks function about the same as the dodge trucks. https://i.imgur.com/P41Aywo.gif Has anyone had any issues using the transfer rod from the GM to the 47RE? or are there better options for this? |
