What differential rear end do I have???
I was gonna replace the differential fluid in my new to me 1970 GMC LWB 1/2t. Don't see a drain plug or a fill plug (are they on the front of the differential?
Can we tell by outside pics what kind of gears etc I have? My SPID is long gone (previous owner replaced the glovebox with chrome one). Original seat was replaced also so no paper/sheet in the back of the seat. |
Re: What differential rear end do I have???
12 bolt truck. No drain plug. Fill plug is on passengers side of case in front of axle tube.
You have to take the cover off to drain the diff. You can inspect the gears while you are in there.
Thanks guys. That wa s the only pic I had of the truck. After I posted it I figured fill must be on front. So if I have to take the cover off I’m also gonna need a new seal right? Any recommendations as to brand etc? Or just whatever my autozone has??
Fel-Pro RDS 13391...Any GL-5 MP Gear Lube in the 80w/90 will work...
turn
Once you get cover off you can get gear ratio from numbers stamped on OD of ring gear. You will also know if it has a limited slip and if so you will need to buy the friction modifier additive.
Op, a factory Lsd will look like this.
Turn
Thanks guys. I'm a total newb at all of this. All of these gears look like drilling equipment to me. Haha.
So, I have a 12 bolt and when I get the cover off, where specifically are the numbers I'm looking for?? Just want to be sure I get all the info I need while in there. Also, I picked up gear oil (80-90w) and the fel-pro gasket last night. What' proper procedure for putting the new gasket back on?? Do I need sealant as well? If so what type? Just don't want to make things worse by getting in there and screwing something up. I plan to take a bunch of pics but don't want to go back in if I don't have to. ;) |
Numbers in the red block. I don't believe felpro gaskets require sealant.
I'm not advocating not pulling the cover but if you jack the rear end up, put it in neutral and make a mark on your driveshaft you can make a very close estimate on gear ratio.
In one full rotation of your rear tire the driveshaft mark will go past 0 point X amount of times (short of 3 turns 2:54, just over 3 turns would be 3:04, 3-3/4 would be 3:73 etc.) Backyard trick I picked up when I was a kid... MOD |
If you decide to use a gasket sealer (I always do, gives me peace of mind), get Permatex 81182 -- it's made specifically for use with gear oil.
https://www.permatex.com/wp-content/...6/02/81182.jpg |
Thanks again everyone for the tips. I usually drive new/newer vehicles, and usually have the maintenance done by a pro. So intentionally getting into stuff like this is not typical for me. haha
But, I want to know that the running gear is OK before I start driving it around and especially if I put my family in it. A good friend of mine who has been working on vehicles for over 50 years is my mentor and though he is kinda tired of working on them, he gives very good and important advice. He said "check and change the rear end oil" so that is getting done. Figure while I'm in there it's important to find out what I have. Might be kind of a Duh question but, I'm guessing it's better to change/fill fluid while it's on level ground? Correct? But to see the side of the gear I may need to jack up the rear wheels to spin the gear?? I usually lift the rear with jack under the pumpkin. Should I put the rear on low jacks, pop cover off, drain, ID the gears, put cover back on, then drop wheels on the ground then add fluid? Also, I've read where some people use a little RTV with the fel-pro gaskets?? Do or don't do that? And if I do, how long should I give the RTV to dry/set before filling with oil? Lastly, what are the torque specs for the rear end bolts? |
3 Attachment(s)
Some external pics, hoping to get into the differential tonight.
Chiming in. I did this with mine last year, because the gasket failed. A light coat of the permatex will prevent any weeping.
On a side note: Does anyone know where to get an "S-clip" these days? We used to get them when I was a kid (like 35 years ago) The clip will "tighten up" a one wheeler to make a poor man's posi |
forget gasket......... use permatex ultra black rtv. works a lot better as for diff lube use synthetic , you,ll never have to change it again ever. wash rear out with spray starting fluid.
Light coat of permatex on both sides of gasket. Let it tack over a bit, then install. Bolts do not need much torque at all, whatever service manual says. I’ve never had a leaking diff cover in my life doing it this way.
Bolt torque for the diff cover is specified on page 464. Dana 60 gets 35 Ft-Lbs.
So I have a Dana 60?? |
12 bolt gm
3 Attachment(s)
Here are the pics. I've got it all sealed back up, filling it back up tomorrow.
