mechanical fuel pump
So I have a Vortec block with the machined housing for a fuel pump. My issue is no hole to access cam lobe.
I would like to drill to accept the pump. Has anyone done this? |
Re: mechanical fuel pump
Its a bit more than drilling the hole. It does not look like the hole is cast the same in the side of the block on the one I have. Would need to fins a good size mill to put it in. Its got to be dead on.
Jimmy |
I'd just run electric pump. ...
https://www.ebay.com/itm/FUEL-PUMP-C...T7M61vesWsktFQ Read carefully, Call them (Like it says in the description). Here's a video of the same kit being used. https://www.youtube.com/watch?v=zLU5mfMvwlw |
I have seen the jig, expensive.
My block has all the machining ,it even has a hole . It's on the letf side But the hole is not open all the way through There is someone on YouTube just drilling his way through, looks a little cave man. That is what I was thinking about doing. |
