292 Push Rods
I feel like kind of a dumbass but I am going to ask anyway. Is there some trick to dropping in the push rods on a 292 after the head is torqued down? This is the first time I've put a 292 head on with the engine in the truck ('63 C10). In the past I have done the assembly on an engine stand.
The #6 push rods are not even close to standing up straight enough to drop in. I thought about a hole in the cowl to be plugged later but that's just embarrassing. D'oh...ned. |
Re: 292 Push Rods
I know nothing about 292's so just shooting off the hip here. But don't they have inspection covers on the side of the block that you can take off?
Re: 292 Push Rods
For those that don't understand the problem, on some applications there is not enough room between the firewall & top of engine to drop the pushrod straight down. Drilling a hole in the cowl is probably the way you will have to do it. I wander if a guy could pull the lifter out & put the pushrod down in the hole & up into the head. Then put the lifter back in. Usually you have to have the pushrod in the head with a wire or close pin .
Re: 292 Push Rods
Re: 292 Push Rods
Here's a picture of the #6 intake push rod trying to fit into the head casting. The top of the push rod needs to go back about an inch to drop in through the castings. Just to give an idea to those who can't picture the problem.
Re: 292 Push Rods
Unbolt the trans and jack it up to tilt the engine forward?
For others, the slot in the head acts as the pushrod guide, so you can't just drill it bigger. Must confess I've always pre-assembedl my engines out of the vehicle - but I can see how you got here. |
Re: 292 Push Rods
Re: 292 Push Rods
Compressing the No. 5 & 6 valve springs with the 292 in-situ can be a problem, too.
I had to modify the wonder-bar type of valve spring compressor, by drilling an almond shape out of the flat part and inverting it. The pushrod then rides thru the hole, while you work the bar back-handed. Disconnecting the forward mounts and lowering the block is the only solution I can think of. |
Re: 292 Push Rods
Depending on how original the truck is, I would be tempted to do as Wrenchbender said. Drill a hole in line with the rod opening. Push the rod up and then drop it down then patch the hole and paint it. Otherwise, it's a lot of work.
Re: 292 Push Rods
Or drill a hole and plug it with one of these...
https://www.homedepot.com/p/3-4-in-K...6072/100200567 |
Re: 292 Push Rods
Once I have the time, I plan to drill a 7/16" hole for each pushrod. One will come up through the cowl lip, where the back of the hood meets the cowl. The other will go through the curved firewall up behind where the underdash heater air hoses run. I'll patch the hole in the cowl lip in a manner TBD. The other hole will get a proper firewall grommet and I'll use it for the tach, oil pressure, and water temp gauge wiring. In the picture above you might notice the tach signal wire going through the firewall in a simple hole with some RTV smeared on it..
I'll post some pictures when the deed is done. |
Re: 292 Push Rods
Can I ask a question related to push rods? I also have 292 and did a new head gasket. I marked all pushrods to each cylinder and what was top a bottom. I noticed one end of each rod has a chamfer around the hole and the other end does not. Most had the chamfer down and a few had the chamfer up. Does it matter and what is the chamfer for?
Re: 292 Push Rods
OLD post but----pull the pushrod up to a comfortable spot where it won't interfere with lifting the head. Then take a heavy duty rubber band to hold the push rod in place. Lift and remove all as one. There are more than one vehicle I have used this method on. I think a V8 Monza comes to mind--been awhile
Re: 292 Push Rods
That's not a pushrod - that's a walking cane!
