1996 cam offset timing
Had to replace my lower intake manifold gaskets. I installed the dizzy back as close as I could, but had to turn the dizzy almost full counter clock wise to get the check engine light not to come on while its running. Anyways, does anyone know of a scan tool that can read the cam offset timing? I have one of those cheap code reads but I would like to get something alittle better anyways. Thanks in advance.
Re: 1996 cam offset timing
Snap-on Solus and Pro versions.
Its going to cost you alot more then paying a shop to read it for you.
