Air bag pressure
I’m running a triangulated 4link on the back of my ‘55 with an accuair setup. For some reason I have way more pressure in one air bag than the other to keep truck level. Any ideas? Each side is set up exactly the same and am running the Firestone sleeve type bags.
Re: Air bag pressure
The last possibility is how you are measuring the pressure, two different gauges of a single dual needle. You could swap the gauges or lines to make sure you have similar readings for each corner. |
