Flip kit after 4" lowering kit?
I just picked up a 93 C1500 Sport and I wanted to lower it so I went with Belltech 2-3/4 lowering kit with the coil springs and I like the look but I think I want it lower, how can I put in a flip kit now that the springs have been lowered 4"? I assume a flip kit by itself gives you 6" and if it is already 4" with springs then 10" would be way too much. My original spring perches are a bit beat up from chiseling the rivets out and the truck came with 2" rear drop shackles so I do not have the factory ones.
Thanks for any input. DH |
Re: Flip kit after 4" lowering kit?
You will need to buy new stock hangers (or spring perches) and stock shackles. You can bolt the hangers on with grade 8 hardware similar to the lowering hangers. I took a 2/4 dropped truck down to 5/6 & used hangers from Rock Auto. It should be a pretty simple part swapping process other than the c-notch need for the flip kit. Are you planning on doing spindles up front at the same time to lower the front more too? |
Or buy lowering leafs to get the rear down and forget the flip kit.
JWall
Ok that is what I figured I would need to do but just wanted to double check. On the front I will be doing drop spindles but I haven't decided on which brand yet, whichever allows me to run my stock 15's until I figure out which 20" wheels and tires with what offsets I need. I know I have to grind some lower control arm away but I want ones that will allow me to grind the least away. |
