Blazer Rockers
Do Blazers have an inner rocker panel? Or does the rocker box do that job? My outer rockers are almost gone and I done see any remnants of and inner rocker. Just trying to get an idea of what I'm getting myself into. Oddly, my rocker boxes are in GREAT shape.
Re: Blazer Rockers
Yes on the inside of the curved outer rocker is a flat piece that makes a 90* angle with the floor. Search for rocker replacement images and you'll see plenty of images of the guts there.
Re: Blazer Rockers
Ok, thanks. I can see straight into the rocker boxes, so they are either missing or rotted out worse than the outer rockers. Anybody sell a THICKE rocker set than OEM or reproduction?
Re: Blazer Rockers
Re: Blazer Rockers
Re: Blazer Rockers
wow. That's a big deal. Are the clecos just to hold it or are you going to rivet it in?
Re: Blazer Rockers
I welded mine, that's how the factory did it.
Good luck, Rg |
Re: Blazer Rockers
Here is a break away (rusted away actually) view of the blazer side from an old project of mine.
Re: Blazer Rockers
thanks for that. looks like I've got some work ahead (x2). I had thought about making an inner rocker out of something thicker to tie the rocker box and floor together, but it looks a bit more intricate than that.
Re: Blazer Rockers
The repro panel is a good one. For a Blazer application the rear of the panel will have to be slightly shortened. The panel was designed for a regular pickup cab, but works fine on a Blazer.
Re: Blazer Rockers
If I remive the fender and door, will I see the end if the firewall like in your first picture?
Re: Blazer Rockers
The fender, inner fender skirt, and door will need to be removed to see the firewall as seen in the supplied photo.
Re: Blazer Rockers
When I did the rust repair on that part of my blazer rebuild - I was given a free part to test the fitment with a new aftermarket piece - have a look here at my review. It wasn't that tough.
http://67-72chevytrucks.com/vboard/s...d.php?t=375946 |
Re: Blazer Rockers
I'm pretty sure I won't need that part... fingers crossed!
Re: Blazer Rockers
Hows your B pillar? Also any rot in the floor pan?
If you have floor pan rot your subframe might also be gone. |
Re: Blazer Rockers
Floor is good at the b pillar on both sides. Just rockers and usual adjoing floor
