49 Chevy 3600 216 to 261 Radiator work
Guys
putting a 261 in my 49 Chevy 3600. I have run into some radiator clearance issues. 1. I am using the short shaft water pump. 2. I am using the 1962 Fan. it bolts right up but had to use spacing washers to bring it out past the harmonic pulley. not quite an 1/8. In doing the above I now the fan is right up against the original 49 radiator in the factory mounting position. I moved the radiator forward to the opposite side of the factory location I have clearance. BUT With the 1962 fan now there is no clearance in the lower radiator outlet. I have almost 1/4 inch clearance from the tip of the fan blade to the outlet neck. Not enough room for the hose. Any advice? Thoughts I have is to: - Have the radiator shop extend the neck past the fan to allow for hose fitting. - Nip off a little off each fan blade. - Offset the radiator to the passenger side to gain space. This would require taking a 1/4 inch off the passenger side of the radiator flange. |
Re: 49 Chevy 3600 216 to 261 Radiator work
I have a similar problem. I'm going with electric fans.
I think there have been some guys who had their radiator outlet cut and welded back on at an angle if yours is straight that might work. |
Thanks. Please share the fan system you get and how you wired it.
