TH400 info
have a TH400 in my 67 c10 2wd w/350, want to add a trans temp and pressure gauge and not sure where to look for proper access to add a fitting. Is the cooler line ok or somewhere else on trans case.
Re: TH400 info
In the past, I've welded a bung in the pan for a temp gauge. You just have to be sure there is no interference issues.
Re: TH400 info
thanks for the reply, i was thinking about putting a tee fitting in the cooler line to the radiator, the temp sensor is a 3/8" thread and not too long, try different
fittings to keep the sensor not too much in the flow, not sure if this will be OK for good temp readings. |
Re: TH400 info
My B&M trans temp gauge came with the fitting for the cooling line. It was very simple.
Re: TH400 info
thanks for the info, i'll look it up, next on the list is a good transmission rebuilder
Re: TH400 info
If you put the sender in the cooling line, make sure it is in the line coming from the trans and not going back to the trans.
Re: TH400 info
will do, thanks , think the top line is out, waiting for parts to get here from mail order
Jegs, using their led gauges etc. |
