What's the best and easiest way to get an EFI fuel setup with in cab tank?
I'm so impressed with the Holley Sniper on my '69 427 that I'm considering doing something that would have been sacrilege a couple of years back - putting it on my 402. And while that isn't an LS swap, I'll need the same fuel system.
So I'm wondering what people have been doing for return style fuel systems with an in-cab tank that isn't super noisy? |
Re: What's the best and easiest way to get an EFI fuel setup with in cab tank?
You could use a inline pump...(walbro255)....mount it under the cab...but you'll need a return port to the tank
I'm always afraid the inline pumps are loud, but I guess when the other option is in the tank right behind you, it might be the lesser of two evils.
Any clever approaches to plumbing the return? I was thinking that these tanks are so "deep" that as long as a guy kept it 1/3 full, you'd never starve the pump in normal turns. Or do you still need baffles? |
3 Attachment(s)
Attachment 1798054
Attachment 1798055 Attachment 1798056 Quote:
All the sound deadening wasn't cheap, but it worked. Quote:
The only time I hear my inline pump is when I turn the switch on before cranking.....or if I crawl under the truck and stick my ear up to it with engine running.....mines right at the back of the cab on drivers side...
You can use a fuel pickup/sending unit from a 72 truck and an inline pump, the late model sending unit has a return line built in.
Would a '72 pickup/sender work with my '70 3/4 ton tank?
I wonder if you could mount the pump right on the pickup in-tank? |
Just to confirm, is this the one I would need?
Just thinking out loud, since the in-cab tank is so high, you could actually mount an inline pump more towards the engine compartment and it'd still be gravity fed by the pump. They don't like to pull, of course, but it'd be well fed by gravity once prime was established.
2 Attachment(s)
I envision using a simple weld on sump at bottom center of the tank with holes drilled in tank behind it to make a sort of fuel bucket and prevent starvation. They're super cheap on eBay like $25 and have an/npt fittings already on them. Gravity feed that through the existing holes in the cab floor to an inline pump. There's also the bolt on sumps diesel folks use to cure starvation with similar theory. Then use existing sender for the return through the top.
I added a sump to my tank, and it works really well. The only down side is if you get a leak in a line, it will empty your tank leaving your truck sitting in a pool of gasoline, hoping nobody throws a cigarette it's way, so you need to make sure the lines are good. I made my own on a sheet metal brake, but Ebay does have them for $35. https://www.ebay.com/itm/Mini-Fuel-T...ksid=m570.l131
^^^ You're the only one I've seen do it! Very good pics in the ls1tech thread. Hadn't thought of the potential leakdown issues
