Removed fuel tank have some rust what would you do
3 Attachment(s)
As I mentioned we were excited to get power in cab fuel tank removed but underneath I definitely have some light to moderate rusting issues with some pitting. The truck is already been painted so not sure sandblasting is an option. I've read about different rust treatment things such as POR 15 and Eastman products just curious if any of you have opinions or thoughts? I've also read about some gels and products tht are supposed to help dissolve the rust. Or do I attack it with some sort of sanding/grinding blade. Oh and light rust under the old headliner too
Re: Removed fuel tank have some rust what would you do
I'm thinking wire cup brush and rust converter. Not a big fan of doing it that way but it may be your best option.
You could mask it off and sand blast it without too many problems with a small sandblaster. My little Sears blaster doesn't cover a lot of area at one time. Messy inside a cab though. |
Also do you have any experience with any specific rust converters? |
Mr48chevy
Something like this? Or what do you have if you don't mind me asking https://m.sears.com/search=craftsman...r%20kit%20with |
https://www.harborfreight.com/21-oz-...gun-95793.html
Harbor Freight makes this little gun. I have a friend who uses his regularly. But with that paint in there (and blasting inside a cab is awful...you'll find sand for years) I would definitely just use POR on the inside of the cab. Probably the same on that other part. Do as much mechanical removal as you can without damaging paint. Then POR over what's left. |
Get some Rustoleum Rusty Metal Primer. Blow away the loose stuff & spray it with that. I have used it for years. It seals the rust & leaves a tough coating. You can paint it the next day.
That was basically what I was suggesting with taking a cup brush on an angle grinder to it and putting the rust converter on it. Several ways do do it and help it last for a long time to come.
And thanks mr48 Chevy I'll checkout the cup brush and start there. I'll definitely look into the 2 suggested sandblaster sounds useful but maybe not in the cab like b-mac said but hey I live in the country so good luck she will always be dusty haha Thanks again |
use a rust converter like rust Mort and then paint . Paint is the only way to stop rust look up miracle paint, better than Por :gmc2:
http://www.tptools.com/Bill-Hirsch-M...aint,2553.html |
3 Attachment(s)
so attacking my rust today. Have a wire cup brush which I feel kinda smooths but more so polishes my rust haha. bought a different disk and it's doing better I think as I'm finding some shiny metal but I have a bit of pitting in the floor pans area. guy had it hidden pretty well under spray Bedliner 😣
Any suggestions of tools that might be better? or is this ok? Also those that suggested sandblasting. trying to research mediums to use. any recommendations for what medium might be best in your experience? going to do wheel well area which is just needing light cleaning and then the floor pans and area from fuel tank that has heavier duty rust I was planning a path of rust stop products but thought the more I can remove 1st the better especially the scaly stuff. you can see I am finding some raw metal but have along ways to go. |
I think you're on the right track. Those black fiber disc things you are using work pretty well.
I also have pretty good luck with these things: https://www.harborfreight.com/catalo...2Cf&q=abrasive But I use an old, crappy, plug-in drill. Good for inner corners and such. I was in the exact same spot as you, and I decided to blast the inside of my cab. I live in a fancy-smanchy neighborhood, so I did it inside my garage, inside a tent basically. It was freaking awful, and probably took years off my life. If I could go back, I would not have done it. Either send the whole thing out to have a professional blast it, or clean what you can, convert it or POR whatever, and get to driving it faster. Whatever you do, the truck will probably outlive you... That said, I use coal slag for blasting. Good for rust, cheap, and won't give you lung cancer. Sand works much better, but do a little research on silica, and you'll change your mind. Any of the other media probably won't touch your rust. |
Sandblasting tent of death pics... (as mentioned above)
https://lh3.googleusercontent.com/qi...=w609-h1082-no https://lh3.googleusercontent.com/dc...w1924-h1082-no You can really see my progress on that A-pillar. And I'll admit, clean metal does look pretty. |
Haha sorry but your tent of death gave me a good laugh thanks! I'm in the country so no one to bother but myself really thankfully. I make much less noise than the neighboring tractors. that's a cool looking truck by the way! Thanks for the I info I'm trying the drill before I go to blasting not so sure of my comfort level going there. definitely will research the mediums you suggested. |
On those two places I used various grinding devices and POR 15 on the floor. Note the metal prep requires water wash to neutralize so that might prevent use on an already painted cab. I used brush on Restoleum for the headliner area. My me no
2 Attachment(s)
I made some good progress yesterday. more shiny metal yay! forgot to he a picture |
a knotted wire cup brush works really well. if you have a couple of extra bucks grab a cheap disc grinder at harbour freight or something, it will save your wrists and the drill plus has more power than the drill has and more control if you hit an edge or something. if you do buy an el cheapo deluxe grinder, like a 4 or 4 1/2" model, you may also find a flap disc is pretty handy for the flat stuff. it will remove metal though. if you have a rental place nearby check into an electric die grinder and then use the proper wire wheel for the speed, better than a drill because it turns faster and they do sell knotted wire cups for the 1/4" shank.
for the roof, scrape what you can, do a quick sand and then paint with some good rust paint, like advised. wire wheel may build up heat in spots and try to warp the roof panel. better safe than sorry. on the floor, when done put a good strong light under the truck and then look from the top side for any bright spots that may be shining through. you don't want any pin holes. caulk them up before or after painting, before will leave the floor all the same colour. autobody seam sealer should work and paint will stick to it. |
when wire wheeling ALWAYS wear coveralls or loose clothing and safety glasses or a face shield. the wire tends to come out at a high rate of speed and will stick into you like a needle. trust me, I know.....particulate mask as well as leather gloves.
end of rant |
Definently safety glasses, better yet goggles. He's right, sticks in you... I wish I had just sand blasted, I used a bunch of wire wheels. Lots of flying needles...
I did have a rust resolver I think it was called "defender",came from when I worked at the Hydo electric plants,it works real good,to use it just knock off the loose rust,then cover with POR 15
Thought I should pass along the after effects of sandblasting my cab interior.
Anytime I bump this thing, I get a shower of sand/rust/coal-slag that falls out of the upper rear part of the cab. I've used vacuums and compressed air to try to get it all out. Think it's gone....work on it a little....more sand. Before I paint it, I think I'll put it on an open trailer and drive it to Canada and back. https://lh3.googleusercontent.com/ni...=w526-h1082-no https://lh3.googleusercontent.com/pS...=w526-h1082-no |
b-mac that's look s awesome though so maybe worth the sand?!? But again sorry to laugh but you made my day with the Canada comment.
Thanks for all the advice and concern I'll post a picture later of my gear and progress darn work is getting in the way of progress blah |
