AC blower motor wheel project
5 Attachment(s)
I have been thinking about doing this for awhile. I wanted to see if could get the AC to blow hard like a late model. After some research I found a late model blower wheel that was the right size. I had to buy blower motor with the wheel just to get the wheel. I got it on ebay for $33.00 it is for a 07-11 jeep liberty. The wheel has 41 fins on it and my 72 AC wheel has 29 fins. The fins on the newer one are also much larger. This took me a few hours to put together. The new wheel would require a much longer shaft that my motor has so I cut the center out and I clipped and cleaned up an old chevy blower wheel and epoxied and rivet them together. The fit was so good they self centered themselves. I had to open up the blower housing hole about a 32d all the way around to get the wheel in. Also took some side cutters and clipped the top of the fins at an angle for clearance. This runs smooth and quiet and blows hard. I think on medium it blows about what it used to on high.
Re: AC blower motor wheel project
Now that is a good project. Thanks for that info and pictures.
Classic Chevy Truck Inventions.
You should be given the Ingenuity Award for the year. Bill P.S. what is the difference in the heater only wheel, this may help us non-AC guys too. |
Thanks! I'm sure that will be one of my future mods.
A short video trying to show how it blows out the center vent. https://youtu.be/hcRlWh4QmM8
It's saying the video is unavailable when I try. However your mod is on my list of things to do.
It's not just a Red71gmc problem....I couldn't see the video either. Looks like a very good mod, thanks for posting!
I looked through your driver build rsgt. Your a resourceful guy. My truck originally was the same colors and I wish the PO would have repainted it those colors. It just looks good on these trucks. Especially with the rally rims. Good job.
Your video worked this time. I will be doing this. It looks like it could be used for a hair dryer if I just still had hair.
That looks like it's pretty strong. I wonder if it would work on a 64 SS Impala as well.
rsgt, Here is your link. :chevy: |
2 Attachment(s)
Here are a couple more pictures. I put a heavy weight on the wheel when I glued them together, Then when it was cured I put the rivets in. I put a weather strip seal around the edge of the motor plate before I put it back on the truck.
Tagging so I can find it later. Nice mod!
I did your mod on mine when it put it together a year and a half ago. It works great.
Where do you guys find the time to do this? On my list now twice!
Can't speak for trucks but the hot tip for C3 (68-82) Corvette blower motors was to use C4 (84-96) Corvette blower motors and add a 3/4" spacer. Not sure if they had more blades but they were at a different pitch and the cage was longer. It supposedly worked well although I never did one.
Also, posting just so I can find it later.
