What carrier is this
I'm new to id-ing the carriers, what carrier is this??
Yes, I know its a LS differential :) |
Re: What carrier is this
Looks aftermarket, Based on the shape it may be an Auburn unit. If you are trying to tell the series then need to know the teeth counts of both ring & pinion.
They had to change the carrier with the gear ratio change. The 3.23 won't fit on the 2.73 carrier.
Is that a 7.5" gear? Camaro's had auburn units.
Yes, from a 1995 Z28. The code is a G80, which means usually a Gov-lock.
The Unit pictured is Not a Gov-Loc.
I'd guess the Gov-loc blew into a million little pieces and was replaced with that unit. As stated, probably Auburn.
