ls pedal no responce at full throttle
I need some help with my 79 with a 6.0 lq4 its throwing these codes po507 idle to high.. po0332 knock sensor right side and po101.maf . I checked the wiring for the maf sensor and it checked out and I even unhooked it .the problem stays the same I can push down the throttle pedal to the floor and it doesn't raise the rpms at all but it does speed up using half throttle but nothing pass full throttle.
Re: ls pedal no responce at full throttle
If all three codes came on at the same time, the problem is likely common.
I can't even begin to guess how your setup might be wired, but here are a few suggestions... If you have access to a decent OBD2 scanner, check the throttle response. It should report throttle position. Check power to the MAF, knock sensor and pedal. Most pedals have 6 wires, 2 power sources, 2 signals, and 2 grounds. Check each power source. Keep in mind that some of this stuff is powered by the ECM/PCM so some of it will be 5 v. Also check the throttle actuator on the engine. The knock sensor, actuator, and MAF are all relatively close and could share a common power or ground wire. Look for signs of abrasion on the wiring or where it might be pinched. Check fuses too. Check your GROUNDS! Poor grounds often lead to weird issues, and this sounds like one of those times. This can be done by measuring resistance from ground points back to the battery. Anything over a few ohms isn't good. May need to do a voltage drop test on ground points with the engine running. Ideally all ground points should show 0 all the time, but with higher loads there can be a few volt drop back to the battery. |
Is the truck actually idling high, or is it just reporting that code off a normal idle?
__________________I checked every wire for the grounds and all the other for power. and I cant find out what it is causeing my problem.. I have the metal pedal . I am gona buy a new one and try that. |
Is the no throttle response a new problem, or has it always done it? When you floor it, do you loose all response to the pedal?
Sounds a little like a DBW component mismatch, but usually that will throw its own code and limp the throttle.
07 would have been Gen IV (except 06.5 classics), but I'm not sure if thats true for the Hummers as well. That wouldn't usually interchange with the GenIII stuff, so my assumption is the 07 Hummers use the late GenIII style stuff... I gotta find clarification on that though.
Then it would be the plastic pedal style, is that what you have?
You likely have the wrong TAC as well. What is the part number on it?
I will check in the morning and see what my 06-07 TAC part number is.
I checked both my 2006 and 2007(Silverado Classic) TAC modules and they are part number 12590008. The one you have is for a 2003-2005. You can either get the correct TAC for your tune or you should be able to change the tune to match what you have.
