trans cooling lines ???
im needing to replace trans cooling lines , considering stainless but reviews are not to favorable. Any recommendations thanks for your input.
Re: trans cooling lines ???
I went with copper as it was only a couple bucks more than the steel. I bent it by hand and it should help with cooling a little better than steel. Local oreillys has a bunch hanging in the store. I did each run with one stick so I don't have any couplings or anything.
Buy some NiCopp tubing on E-bay in whatever size your trans uses and bend your own. Bends easy, flares easy, and won't rust. LockDoc |
bought mine at jegs. perfect fit. made from aluminum. easy to tweak
