Automatic transmission in 2 WD Blazer
Saw a rough 2 wheel drive blazer for sale, ad said it was an automatic. There is nothing on the column like the automatic four-wheel drive Blazer there is a stick shift but the transmission hump is very low. The picture doesn't allow me to see the base to see if there's actually gears. Anyone have a two-wheel drive with the automatic transmission with the shifter on the floor? Can you send me a picture? Thanks
Re: Automatic transmission in 2 WD Blazer
There wasn't ever an auto floor shift in these trucks. They were all column shift. You are looking at an aftermarket floor shift kit that a previous owner installed. This is a pretty common modification. Sounds like they also swapped out the auto steering column.
