Saginaw to Muncie Conversion
Hello, I have a 69 Chevy C10 2wd half ton with a 350 Chevy and a 3 on the tree. I want to convert the truck to a Muncie 4 speed floor shift from a car.. I am very good with mechanical work on these trucks as I have restored and daily drive 2 of them.. But my question is is it possible to just pull out my 3 speed trans and bolt in the 4 speed Muncie. Will it be the same spline, length and bell housing. or will i need a new drive shaft and bell housing?
Re: Saginaw to Muncie Conversion
Should be a bolt in as long as the Muncie is a 10 spline input shaft.
If not you’ll need a new clutch disc. I’m not sure on the output splines but I think they’re the same. The shifter is a bit tight to the seat though. You can get offset and taller handles though. This thread would get more answers over in the engine and drivetrain section. You can ask a moderator to move it. By the by, welcome to the jungle! |
Thank you. Appreciate the help. Ill post it over there tomorrow to get some more feed back
