Th350 leak??
Ive seen people say that the th350 doesnt have a seal in the tail and seals by the adaptor plate/ t case is that true? I have what looks like an apacolytic amount of tranny fluid leaking from around the adaptor plate area.
Re: Th350 leak??
there is a gasket between the case and the adapter
Re: Th350 leak??
The adapter seals to the transfer case with a Gasket & the adapter seals to the transmission case with an O-Ring. Uses the same O-Ring as a 2WD extension housing.
They leaked also. |
