Vern, my 77 swb Fleetside Chevy Silverado
3 Attachment(s)
I dont really have a direction for Vern yet, but I wanted to start myself a thread to help keep me motivated.
Vern is an original paint black on black 1977 SWB Fleetside C10 Silverado. I bought it through my buddy Chad (board member CC69Rat and his Pop NoNeck). Its a pretty damn clean 350/350 truck. It had oe A/C ( :( )and has p/s, p/b...it runs out good, as I drove it back to central Alabama from the Chattanooga area when I picked it up from Chad. Heres picks from the pickup day... |
Re: Vern, my 77 swb Fleetside
I immediately put it up on the lift and made myself a list of obvious issues. It had been lowered, but not correctly. The springs had been cut and musta been to low, so they twisted in the ole spring spacers :crazy:. The radiator had a small leak, and all the underhood a/c pieces were missing.
2 Attachment(s)
So, I decided to remedy these problems first. I replaced the radiator with a very nice aftermarket aluminum radiator, a/c condenser, new clutch & fan, hoses etc. and since I was there...I installed a CVF 8-rib serpentine drive setup with a Sandin 508 compressor.
2 Attachment(s)
It didnt have a front swaybar, but I have a 67 C30, thats really just parts, that I pilphered the big a$$ swaybar off of. I got a set of the CPP shorter swaybar mounts & poly bushings. Then I threw it on to help tighten up the tugboat feeling it had on road. I still want to put a set of 2.5 drop spindles and proper lowering springs/shocks up front, but Ive got to get through the holidays before thatll happen.
Today, I also realized it has a 10-bolt instead of a 12-bolt. Didn’t they have 12-bolts in ‘77?
This rearend is a 2.73 deadleg, so it’s truly a pig but it did pretty well on MPG on the drive from Chattanooga. I may just try to track down and swap in a posi. |
Looks like a clean start!
Thanks Wraith! I just read through your build too. Very cool.
Well, I got a hellofa deal on a set of 2.5” CPP lowering spindles and new front springs, so I ordered them up.
Nice work, a 77 should be a 12 bolt, somebody must have swapped it.
That black with the '77 gold is slick!
Well, since it's rainy and crummy out, I decided to go down to the garage and do some tinkering on Vern. I put new door pins in to get rid of the sag related to 40+ years of use. I also put a Comfort Grip steering wheel in to do away with the sticky stock wheel.
I also came to the realization that I'm going to need to do some work to the rear suspension. There are only 4 leafs with no overload spring, so I guess I know how the previous owner lowered the rear. I want to go back to a stock set of leaf springs and just add a flip kit so I can regain the load hauling ability, but have it match with the incoming 4.5" drop for the front. |
Love the name and the truck. Have any interior pictures? Thanks Mike
3 Attachment(s)
I’m actually doing away with that triple gauge setup under the dash as we speak. Only the temp gauge was hooked up, but it wasn’t even kinda right. It was stuck at 190 as the starting point. The stock gauge is stuck on full hot, so I put a single autometer temp gauge in. I also did away with about 100 ft of extraneous wire from under the dash & hood.
Looking forward to watching this. I'm very slowly working on my 77 lwb Big 10.
Looking forward to seeing where this goes! |
Nice start on this one..I will be along for the ride too.
Thanks Rich.
I was reading N2TRUX’s Elwood thread and couldn’t believe he sold it as Vern is sorta cut from the same cloth, albeit no wear as nice. I was already hooked on his Jake thread and now I want a CCSB too. My wife is going to kill me! :lol: |
Well, I've pitched the CCSB idea to the wife and she was actually receptive... On one condition... Vern's for Sale
I just realized I saw your truck on craigs....wish I could make room for it...its a sweet looking truck
Thanks Man! That's precisely my problem. If I'm going to add one, I have to get rid of one... D@mn economics!
Clean looking truck. Looking forward to seeing some more progress
