What type of crimpers for wiring harness?
I am currently building a 65 c10 with ls 5.3 and new wiring harness. I am trying to stay ahead on purchasing things I will need for my build and need some advice on crimpers. What do you guys suggest are a good set of crimpers that will do the job correct the 1st time through? I would rather purchase then rent so I have them for the next project as well.
Re: What type of crimpers for wiring harness?
I just use some klien needle nose for the odd terminals, then solder each one. For others just use t&b crimpers
I got these ratchet crimpers . Be sure to get the ones with all the dies . They crimp all kinds of terminals . Also crimps the ones that curl around . Makes a good solid connection . I used to solder as well but no longer . Before I only got a marginal crimp and soldered it for a solid connection . They work good for a doit yourself shop . I also got one of the larger hydraulic crimper as well makes a real nice crimp for making things like battery cables .
https://www.ebay.com/itm/4-In1-Wire-...AAAOSwSI5bauJd |
2 Attachment(s)
I have these. I used these when I worked in the Repair Dept, at the auto factory. They crimp terminals the same as you would see on any factory harness. I bought both from the same place, it was over 20 yrs ago, but they still have them. Not sure if you can order online. I had to call back then.
https://www.whiteproducts.com/cetools.shtml |
Excellent. That looks like exactly what I need. I will call them Monday.
Thanks you guys for all of your help so far. |
https://www.amazon.com/Delphi-Packar...HA2749JHXS8R99 https://www.amazon.com/Stripper-Crim...17HP5E8SE2Z78E |
