EFI fuel tanks
Starting to research on fuel.
Im thinking of using the TANCINC drop in pump and sender rather than external pump. For a 300HP street only truck - do I really need a baffled EFI tank .... or can I reuse the existing tank. Not sure if that pump will work with OEM tank .... but can find out. Else guess I'll just drop and relocate to rear like everyone else ... but the fuel fillup neck is a little harder on a suburban than "bed only" standard truck. |
Re: EFI fuel tanks
I did the Aeromotive stealth setup in my suburban tank and it worked perfectly. Easy to install and get plumbed
Re: EFI fuel tanks
I'm running the stock tank on mine...344hp....no baffles...I've never had any issues
Re: EFI fuel tanks
currently running a 87 20 gal tbi tank and tbi sender with ep381 acdelco pump for 96 vortec engine . gets me the psi and flow for my aftermarket efi setup no problems. . . . other than the holley sniper sucks a$$ but thats another thread in the main engine section .
Re: EFI fuel tanks
Thanks.
I started a general thread (non efi specific) as not have a fitment issue. http://67-72chevytrucks.com/vboard/s...d.php?t=779126 Want to keep tank on frame rail so I can keep tire under bed. And dont want to have to deal with centering the 8.8 rear. Thinking a shorter tank and a 2" driveshaft. |
Re: EFI fuel tanks
I wouldn't run a non baffled tank anymore imo, tho I run an external and use a bit more fuel than some of yall. Going from 70mph, decel down an offramp and hit a 90* intersection at the end; if i wasn't well over 1/3 tank it was possible to draw air and would stutter on the outlet of the corner. That was with a 15gal cell between the rear rails.
We added tank foam to help the issue until finally switching to a sumped/baffled/foamed cell a little while back. |
