WTB...suburban clamshell parts
I wanted to see if anyone has a lower seal plate that goes from side to side for a clamshell gate to bolt onto available in decent condition. Preferably local but would entertain shipping items also. I am switching my suburban over to clamshell from Barn doors and these are the last items needed. I've attached pics of were the parts would be. Thanks
Re: WTB...suburban clamshell parts
ttt
I should have a spare set of the Chrome tailgate supports but they are not cheap if you haven't found that out yet - 200 a set.
Also, do you already have the clamshell upper liftgate supports? they are even higher but I think I have one |
let me clarify a little bit for the hardware that is needed for the lower gate. I don't need the tailgate supports I just need the part that goes above it that the lower gate will latch to. here is a pic from another burb I found. I have both the lower gate and upper gate supports.
I probably have those catches. With the storm tomorrow I can't check until Friday, but I'll let you know.
ok, thanks for looking everybody!
Just checked a couple of my trucks, your top and bottom center barn door catches are the same as left and right clamshell, so you can just relocate them. I have extras if you need them.
awesom! thanks for looking and noticing that. i can use mine then.
ttt
ttt
ttt
ttt
I believe i have those parts will know forsure Monday
Are they the same as the top and bottom of the doors?
It's actually the catches that are the same, not the latches. None of the latches interchange.
