Rag joint bolts
Does anyone know what size the bolts that hold the rag joint to the steering box are?
Re: Rag joint bolts
Buy it from lmc because their is only one bolt out of the 3 if i remember and be prepared to drill out the ones that aren't bolts unless you're taking out your steering column
Re: Rag joint bolts
The steering column is out and I just need the bolts. LMC doesn't have them separately. I thought if I could get the size I could buy them locally.
Re: Rag joint bolts
Just to clarify, I am looking for the bolts that hold the rag joint to the steering column shaft.
Re: Rag joint bolts
Can you go to a parts store and check the Dorman (help) Section for the correct ones? I thought mine had splines in the shoulders,for a special fastener
if i remember right??? but do not quote me on that ..... |
Re: Rag joint bolts
If you are talking the pinch bolt.....Factory uses a 12 point headed bolt. You can use an allen head style. 3/8'' fine thread, 1-1/4'' long , should be grade 8
Re: Rag joint bolts
Sorry, guys. These are the bolts I am trying to size.
Re: Rag joint bolts
save yourself the time and order the complete setup
