1980 Stepside gmc
3 Attachment(s)
I thought I’d do a build thread on my current project. I bought what I thought was a rust free 1980 stepside truck that was once a city of Palestine Tx city truck. The transmission was shot but it cranked and ran. It was supposed to be my “shop” truck but has turned into a full build. I’ll try to catch up to where I’m currently at in the build and keep it updated.
Pic from when I first got it and was carrying it to the trans shop Attachment 1873390 Pic after it was running and driving Attachment 1873392 Pic with porterbuilt arms and bags in front with 6” drop in rear Attachment 1873393 |
Re: 1980 Stepside gmc
3 Attachment(s)
then came the billets! Along with a narrowed 12 bolt Posi with 3:73 gears
Attachment 1873395 And bagged the rear with just a c notch Attachment 1873396 This is where it turned full build! The truck was originally school bus yellow and had a cheap, low quality, old paint job on it. I couldn’t stand looking at the yellow, especially the inside. So I started blowing it apart Attachment 1873397 |
5 Attachment(s)
So much for rust free. I climbed all over the truck when I purchased it but there was some hiding in both wiring channels and after blasting the passenger side body support had rust
Attachment 1873400 Attachment 1873401 Cab removed Attachment 1873402 I had painted the rear and front of the frame and with the cab off, I cleaned and painted the rest Attachment 1873403 Body mount rust after blasting Attachment 1873404 |
5 Attachment(s)
Cab blasted
Attachment 1873409 Rust repaired Attachment 1873410 Attachment 1873411 Etching primer Attachment 1873412 Raptor liner sprayed Attachment 1873413 |
5 Attachment(s)
First time I have ever sprayed raptor liner. I was very impressed with it!
Attachment 1873415 Cab back up right and stripping all of the factory black gunk off firewall. I also welded up the blower motor hole. I will be using a vintage air ac and the block off plate is ugly Attachment 1873416 Finished prepping the interior and primed Attachment 1873417 Attachment 1873418 And I found another spot of rust in the passenger side cab corner. I cut out that section and repaired it but forgot to get a pic Attachment 1873419 |
5 Attachment(s)
Body work done on cab and ready for primer
Attachment 1873426 Outside primed with ever coat super build 4:1. It was the first time I’ve used it and I love it!Attachment 1873427 I sprayed all of the inside with white raptor liner except for the dash Attachment 1873428 Attachment 1873429 Attachment 1873430 |
4 Attachment(s)
Dash painted base/clear white
Attachment 1873431 Outside blocked and ready for paint Attachment 1873432 Base coated white Attachment 1873433 And cleared Attachment 1873434 This pretty much brings me up to where I’m at now. I started cleaning up and painting interior parts and mocking up my vintage air unit |
Love the truck. Can't be a square stepside!
Looking good! I thought it looked good bagged with the rallies hahaha
Posted via Mobile Device |
Cannot wait to see it finished. Very nice build
Wow really nice job!
Subscribing to this one.
Cool truck! |
Wow..This is going to be another beautiful Stepside..
How much did you have to narrow the rear end?
I love watching these builds progress. Awesome work!! Mike
work looks great!
Looking sick... if you have time and the bed is still off, can you snap some more pics of how you did the rear suspension?
Thanks for all of the compliments! I have been working on the truck pretty regular. I’ve been cleaning, blasting and painting a lot of parts, bolts, nuts, brackets and etc. it’s time consuming and doesn’t make for any cool pics.
4 Attachment(s)
Attachment 1878041 Attachment 1878042 Attachment 1878043 Attachment 1878044 |
5 Attachment(s)
I installed noico 80 mill butyl sound deadener inside the cab and started putting some things back in/on the cab. I cleaned up the inside wiring harness and rewrapped it also.
Attachment 1878047 Attachment 1878048 Attachment 1878049 Cab ready to go back on frame Attachment 1878050 Cab on frame and bolted down. I also installed driveshaft, valve covers, intake manifold and water neck Attachment 1878051 Today I also painted the drivers door hinges, some bolts, and the vintage air block off plate base/clear white. I had planned to paint the passenger side to but it needs bushings. I’ll paint it with the next batch. I have also started body work on the passenger door and have been looking for a clean drivers door but have not been able to locate a decent one. The original driver door was straight and rust free but was cracked around the upper hinge bolts. I have a parts truck out back that has the large tow mirrors that otherwise has decent door on it. It’s looking like I’ll be welding the holes up on it, unless I just get lucky and find a door |
I left out that I also finished cleaning up and painting the motor that came in the truck and installed it with the trans back into the frame rails. The motor ran good and I’m hoping that the Edelbrock carb/intake and a set of header with dual exhaust will waken it up a little. Oh and the narrowed 12 bolt has 3.73 gears where the original 10 bolt was 3.08. That should help also
Attachment 1878056 |
I'd like to see the actual links on both ends of the trac bar. Well done!!! Thanks Mike |
I toke out 3.75” per side |
