1976 GMC Suburban 6.0 LS
5 Attachment(s)
Asking $9k USD - can help with delivery, will answer all questions, etc.
swissarmychainsaw@gmail.com I would trade for a "non-smog" blazer of similar value. 1976 GMC Suburban K15 90K original miles 2 tone paint 4x4 Clean Title with valid Michigan plates. MORE PICS HERE LS 6.0 with a Holley 670 Avenger and headers and cam - it makes a glorious noise The interior is super clean and shows the original low mileage. Not perfect but it's the nicest mid 70s 4x4 you'll likely find. Off Road Design (ORD) - springs all the way around, custom made, about 3" of lift Goodyear Duratrac tires 33" New Bilstein shocks Electric fans Rebuilt tranny NP203 transfer case with Part time kit (works great) Have all parts to install front and rear air conditioning Positraction rear end (love this!) Stock bench seat is perfect (I put in Corbeau buckets - optional) Holley 670 Street Avenger Bad: Clear coat is failing, but still looks decent Passenger fender has rust in the usual place Tranny weeps a bit, I believe it is the shift shaft seal Carb works good (could use a touch of tweaking, I have a jet kit and stuff) FYI - This is not California Smog compliant. MORE PICS HERE |
