While the 250 is pulled...
Changing out some gaskets on my 70 250 and decided it’d be easier out of the truck. In any case, with them engine out, what else would you guys be looking at or replacing?
Re: While the 250 is pulled...
Check or just go ahead and replace the clutch, pp, release bearing and pilot bushing and at least check the flywheel for heat cracks, replace if necessary (assuming you have a manual trans). Check brake lines while it's easy to see em.
Thanks Jocko. Clutch flywheel etc being replaced. U joint and center support being replaced. Planning on water pump and radiator based on age and condition. Debating if I should pull the bed. Engine was running fine when parked last fall but if I have it pulled I want to make sure I cover all my bases.
If you're pulling the oil pan for a new pan gasket, it might be smart to remove one of the crankshaft bearing caps to see what kind of shape the mains are in if you don't know the history of the engine. In my case this was the deciding factor in NOT putting anymore money into my old SBC (i.e. getting the heads cleaned up, new gaskets, etc.) as the main bearings were discolored and had scratches in them even though the engine ran pretty well.
While the engine is out and they're easy to get to. Core plugs ... core plugs ... core plugs.
(often erroneously called freeze plugs) |
Got it, I’ll add core plugs to the shopping list and bearings to the inspection list!
Thanks for the help guys, as suggestions roll in I’ll keep updating my list |
Any thoughts on head gasket replacement? If yes, any thoughts on head bolt replacement? The ARP studs are $120 and seem a little overkill for a straight six freshening up. Can I just get grade 8s the same length as the bolts I pull?
Front shocks, any rubber seals on the firewall that are going bad. There are likely other things that are easier to get to while the motor is out.
I'm going to ask the obvious question here. Have you done a compression test on this engine yet? Would be a shame to put all of this time and money into a dud of an engine.
Thanks! This is a great community. I’m learning a lot along the way (younger ish guy here)!
...in addition to what has been listed;
Hoses (all) belt(s) motor mounts battery cables plugs, wires, cap, rotor (points & condenser if applicable) fuel filter oil filter since you're in there: You might look at the timing chain ...Or are those gears? Oh yeah, That little rubber grommet that goes around the clutch fork, in the bell housing I always have a problem with how far to go, and where to stop on these kind of projects. Good luck, it sounds like a worthy endeavor.:cool: |
You and me both. It’s always just one more liiiiitttle step
No compression test. My feelings are that outside of the labor and gaskets most parts would interchange if the block ended up bad. I would write it off as a learning experience. I’d like to stick with a 250. I’d been driving it for a year as is with no real issues. This all started with replacing a clutch, and led to a little scope creep.
Did all that with my 250 about 10 years ago when I upgraded to the "marine" cam for a bit more performance. Pretty common back in the day. |
In my head this is a “Stage 2” of the truck. Stage 1 was steering and brakes to get it around this last summer. This will freshen up the 250 with the idea that it runs til it doesn’t. Then I’ll figure out the final direction...maybe hunt down a 292 for a full build
Speaking of brakes (if you didn't do this): fresh front brake lines. Much easier to do from the top than the bottom.
Done with the disk swap! And you’re right, would have been much easier from the top!
If you keep it outside in the winter, I'd say add a block heater. My 350 starts and behaves a lot better on those cold mornings. I've been thinking about a heat pad for the bottom of the 700R4 too.
One thing I did when I had my engine out was touch up the paint on the frame, crossmember, and flywheel cover with some Rustoleum. I also washed and waxed the firewall behind the engine, changed over the wiring to run an HEI distibutor (got rid of the resistor wire), and ran a new wire for the electric choke.
Were all these 250s stock with a composite timing gear? Has mine been replaced?
If it's metal, you're good to go. |
Keep us posted on this. I'm curious to hear how it goes for you. Oh, and good luck!
