started building my 441 heads. tips 4 ya,ll
today I started building my 441 heads and thought I,d share a couple tips I,ve learned over the years.
1. when going to screw in rocker studs and guide plates.. YOU MUST DRILL OUT THE FACTORY OVAL SHAPED HOLES FOR PUSHRODS TO 7/16. USE A NEW DRILL BIT WITH A DRILL PRESS...............AND USE CUTTING OIL GENEROUSLY........ 2. WHEN REMOVING PRESS IN ROCKER ARM STUDS........... HEAT STUD BOSS BEFORE YOU START THE PULLING PROCESS. MORE TO COME BOB |
Re: started building my 441 heads. tips 4 ya,ll
I'm in, let's see your progress. I love a good rebuild with all the juicy details.
got pushrod holes drilled out to 7/16 also got all rocker arm studs pulled and all valves n hardware removed. now off to machine shop with em.
well finally got to work on my 441 heads, I found out I have the desired Canadian heads. yee haw............all the nhra super stockers want this head because it flows 10-15 % more than the U.S. 441 HEAD. on with the grinding
Did not know about those differences. I have a set of 441 heads on my vehicle and would love to see some casting marks that show the id marks.
I can say this, they aint super fast but they have been very durable. |
Comming
x2 would like to see the casting marks
in on this
There were two designs of Fuel Injection heads- the ones with 1.94" intake and 1.50" exhaust valves, and the ones with 2.02" intake and 1.60" exhaust valves. On the 2.02/1.60 heads, the valves were extremely close together. These tended to crack in the area between the valves.
I'm guessing you have the 2.02/1.60 heads, Bob? |
1st thing 441,s arent fuelie heads.............. yes I,am going to large valves. Canada heads have 441 cast into them on bottom side length wise on int. port, us heads have 441 cast in width wise. there heavy castings. people say go modern alum heads but what they overlook is all the cheap import heads need work b4 install so true cost is a lot higher. nothing is better imo than gm for our use. lastly when folk say closed chamber is better by the time you open chamber up so int valve can breath its not 64cc chamber anymore. go 76cc and use .125 dome pistons to get 10-1, fine tune with deck height and gasket thickness. IMO I,AM NOT BUILDING A RACE ENG. JUST A REAL 355 / 350HP ENG.
Oh, OK.
I have some real nice fuelie heads 4 sale off 327 / 300 hp engines
I,ll have some pic,s tonight 4 yall
3 Attachment(s)
Pic,s. Of 441 heads made in u.s.a. Note how the 441 is cast into the head cross wise on int. Port bottom. THIS HEAD HAPPENS TO ALSO BE A " X " CASTING WHICH I NEED 1 TO MAKE A SET IF ANYBODY HAS 1 FOR SALE REASONABLE, CORE IS FINE IN FACT PREFERED..
Got my dart s/r head side by side WITH my 441,S today.......boy what a difference....... The dart head has pueney intake ports when compared....i dont see how dart sells these.................
Pic,s comming
If your new heads are the 170cc intake port volume S/R heads, THOSE are awesome heads. They actually have more port volume than your 441's do. I have a set I plan to use on a SBC 400 some day.
Remember when looking at ports, it's not the size that's most important, it's the shape!!! I seldom hear on this board about them, it's all about Vortec's or aftermarket stuff. The 441's are great heads, the S/R's are even better!!! |
a little hose cant flow as much as a large hose. I had these on a 383 and wasn't a bit impressed JMO SPECS TO COME. IMO IF YOUR INTO PERF AND WANT DART GET PRO 1,S
my buddy took some pic,s. 4 me but only 1 was barely any good. I tried guys. I,ll get more but it will be when heads are assembled.......
bob |
