pondering the thought is it worth it?
was thinking about in a year or so swapping my v6 vortec to a 350 is it really worth the swap, because after looking at the stock specs its not a super boost in horsepower or really torque for that matter?.
so my question is is it worth doing it, keep in mind am looking to swap to a 94 power plant 5.7 so i can try interchange some of the accessories onto the v8. sure some stuff is compatible. dont get me wrong i love the v6 it's a workhorse motor. never make them the same like that again, chevy had passion back then, i dont think the trucks today have the same appeal. |
Re: pondering the thought is it worth it?
Anything is possible. Depending on the year, it could even be remotely simple.
I'd only ask one question: What are you looking to accomplish? Figuring that out will help to reveal whether it's worth it. Certainly, there must be some drive to want to make the swap. Once you find that, it'll be easy to weigh the value against the cost. |
Like Shifty mentioned, any reason for the change? You'll need new computer/ECU Chip possibly all or at least some of the accessories, radiator, exhaust, and the engine. My V6 did everything my V8s did just not as easily. Unless you had the engine, and the V6 is need of replacement, I would probably go with another V6 for a daily driver.
i think your right v6 is a great little motor . also i had a buddy has a 6.0 04, he says it's killing him at the gas pump his daily commute, stick with the v6 he said they are great motors. reason for the post was getting others 2 cent inputs on it, thx ..
You can always improve the V6 with some tweaks. Since yours is earlier, you can always go to high flow cats and better exhaust. I know my 02 (and newer) ones had dual cats. Making it true duals greatly improved mine both in drvieability and mileage, except when I always pushed the loud pedal to hear the good sounds it made! :lol: :rolleyes:
Yes its worth it. The sound of the exhaust alone is worth it.
what would be the best way to go guys doing this, find a legit 1994 350, keep in mind i wanna try cross over some parts to the v8 if i do go for it , after my boats restored though.
The up to 95 350 would be the easiest. Noty sure what all you can cross over from your V6 though. If I was going to go thru all that with computers needing changed and all, I would go with a 5.3 or 4.8 LS. The 4.8 will do some very decent mileaghe too, probably as good or slightly better than the 4.3
The only way I would do that swap would be if I got a deal on a complete donor 350 truck of same year, or at least exact same components as your year. Nothing wrong with the 4.3, a great motor that lasts
I would keep the v6 but I'm a six banger nut so I guess I'm biased.:lol:
