81-87 rear brake circuit have residual check valve stock?
Do 81-87 rear brake line/ circuit have residual check valve stock or is it just a strait shot from the combo valve to rear brake hose?
Thanks Clint |
Re: 81-87 rear brake circuit have residual check valve stock?
Wouldn't the Residual Pressure valve be located in the outlet of the Master Cylinder for the rear drum brakes?
Isn't there a valve in the prop valve that can flip and not give pressure to the rear? Should light up the BRAKE light on the dash. I believe there is a tool to hold it in place while bleeding
Cpp has a tool to keep the Brake light from tripping... pretty crappy quality, its threads are too small so it feels like it is cross treading.. will it work yeah, will it damage anything no, but I will probably mak a tool out of the old sensor that I probably wont ever use... I picked up cop disc / disc valve finally.. I'll install it in a few weekends.
Just replaced the rear drop brake line.. Sum b, had to replace the brake end fitting as it rounded off. Clint |
2 Attachment(s)
Slightly off topic, but has anyone ever heard of anti-locking rear brakes on an 87? Any information on them? Just noticed it's on my window sticker.
Rob, 88's had it standard, so it could have been an option in 87. I have never owned or driven an 87 so not sure. Newest square I have had was an 83.
I don't know if the 1/2 tons had the same valve. If so, GM may have called it anti-lock brakes, as a marketing gimmick. Keith Seymore would know what's meant by "anti-lock brakes", I'm sure. |
