Sail panels, deluxe heater control , & more
5 Attachment(s)
Sail panels - driver quality with some scratches and dings, one screw hole broke. $75, Sold
Deluxe heater control with cables and harness , no broken levers , good knobs . $80 sold 1962 Aluminum headlight bezel, driver quality with some small dents and dings around the bottom $50 RV junior mirrors- plenty of patina, one head cracked . $75 Sold 1966 1/2 ton clip type hubcap. Rough condition $15 Gas filler neck-$30 Cowl / kick panel vents- good condition, some surface rust , gaskets still good. $60 Steel upper rad hoses-$40 ea V8 upper rad bracket with rubber cushions -$50 sold Glove box door. -$30 All prices are plus shipping. |
Re: Sail panels, deluxe heater control , & more
5 Attachment(s)
Few more pics
I'll take the better of the two steel upper radiator hose/pipes. Will send you a PM.
i'll take the heater control.
I will try to get some totals with shipping this evening when I get in from work
Man, been looking for some upper radiator steel tubes =/
Matk me second if it doesnt fall thru . . . |
Yes , I have 2.
I will take the upper radiator bracket for V-8, if it is correct for 64 year. Thanks
I little closer look at both steel upper rad hoses . both have some pretty bad pitting and rust, probably not worth taking a chance on
pimpston65 and chtr65 I can fit both your parts in med. flat rate boxes. sending pm`s shortly |
Too bad on the upper radiator pipes, appreciate you checking them out closely.
payment sent.
If you decide one of the radiator pipes is beyond usable, I might be interested in trying to create a cad template from it that someone could take down to the muffler shop and have one bent out of stainless.
Winston, the heater control is on the way. You might even have by now.
Are both radiator pipes sold?
LostMy65- no, I still have one.
Did you say it was pretty rusted?
Would you do $40 shipped? |
It's pitted on both ends. Let me see how much shipping will be.
Bump
I like to see more pick of the glove box door ..shipped to 95407 ?
I will take the glove box door ,shipped to 95407
