Vintage Air Top Mount Squeal
Anyone have a VA LS top mount and have squealing issues (or not)? I drove the vehicle for a long time before putting on the VA bracket/compressor and never heard any squeals/chirps. Now it does it a lot, I installed a shim they provide and it still does it every now and then. The compressor bracket is 1 groove wider than the accessories and it jumps grooves making the chirp. Guess I need to shim it more but I will have to call VA or make a new shim myself.
Re: Vintage Air Top Mount Squeal
My dad's has a chirp too. We had a shop charge the system and they tried shimming it to try and get it to stop but couldn't. I have no way to confirm that it didn't chirp before, but we didn't change anything on the accessory drive other than the high mount compressor.
Thanks for the input, seems it may be an issue with this mount/compressor setup.
It might be, I won't be surprised if others have the same issue. I'm considering a low-mount option on mine just for that reason. I like that it's up high and easy to access, but the number of pulleys and shims and spacers and the squeal turn me off. If I have enough room down low, I'm considering a dirty dingo mount or the mount listed on VA's website. Low mount is cool because it runs off a different set of grooves on the crankshaft, rather than tagging onto the rest of the accessories.
Can you remove a low mount compressor without having to move the whole motor?
The chirp your describing is belt noise I assume? If so what condition is your tensioner pulley in, and where do the marks line up on it? |
I built my entire front end accessory bracket system with a strait edge black and decker level and harbor frieght dial caliper and no squeaks at all.
https://imageshack.us/a/img923/6343/WQTHU9.jpg From my experience in getting alignment down, put a long stait level against the crank pullley and attach it with a quick squeeze clamp. This allows you to use your hands. Crank pulley won't spin... Then it's the dial caliper to the rescue. No need to guess... measure from strait edge to the first groove in the balancer.. Then go and measure the the distance from the same edge to the compressor groove that your using/fits best and shim accordingly. Something you could check... if you rev the engine and the brackets flex.. as in you can see it flex, that's an issue. Not likely, but something you could visually see for free. |
I would rather not go with a low mount if I can avoid it as I want easy access to the compressor since I put so many miles on the truck. I also would have to change a lot of things, pull motor, remove DD mounts, etc. I don't like the looks of the low mount either.
I may end up doing that 87chevy but I don't have most of those tools and I hate to have to reinvent the wheel when I paid $270 for the top mount bracket. On a side note, the tensioner on the new bracket feels weak...it is very easy to move and with a 10 foot belt on it, I could see it slipping easy. I am going to call VA again today, is there another top mount on the market? I may try something else and try to get a refund from VA. |
Thanks, at least there is an option. I am going to call VA and see if they will send me more shims. Then I may try to remove the idler and just run tensioner and a shorter belt on the Kwik. As a last resort, going to ditch the Kwik mount and go with another high mount. The tensioner on the Kwik is suspect to me...I can move it by hand which no way could I do on the stock LS tensioner.
Does the tensioner have wear Mark's casted on the body? It's like 3 marks.
http://www.v8sho.com/SHO/images/belts5.gif Maybe belt is too short? |
I will check that about the tensioner marks. I got the belt from VA's recommendation. I just talked to Kwik and the guy there was super nice and helpful. He is sending me a document on tips to resolve squeaks and chirps. Since my belt is jumping track he said that is a rare issue but does happen occasionally . He said to put 4x 3/8" washers between the brackets and head/water pump to move the bracket out and keep the belt in the back set of compressor grooves. I will give this a whirl when I get some time and post the document on the chirps/squeak resolution.
I wonder if this one is any better. I was thinking of getting this one for my swap.
https://www.ebay.com/itm/Sanden-508-...rd!85213!US!-1 |
Let us know how it goes! I'd like to look at what they sent you so we can try it on my dad's setup.
He didn't send me the document as this is a new bracket that is supposed to resolve the issues on the prior version and is not applicable. I have been on the phone with them near daily and I think 87Chevy has identified the issue, the belt appears too loose. I purchased a shorter belt and will post if this resolves the issue once I receive it. The fixes on the prior version were to shim with 3/8" washers in the 4 places it bolts to the head/water pump if it is jumping track on the compressor (from back to front). Will post part number on the belt if it fixes my issue.
Did the shorter belt fix this?
Posted via Mobile Device |
My vintage air AC bracket is constantly out of adjustment and makes noise. Drives me crazy. Definitely looking for a better option or fix
Belt squeal issue resolved: I removed the tensioner shim and put in a shorter belt that Kwik recommended after calling. The part number is Gates K061115 and it 1" shorter than what they recommended in the instructions. My tensioner on the previous belt was completely released and the belt wasn't very tight, this one I had to pry the belt on to the tensioner with a screwdriver when installing.
