Need help identifying serpentine setup.
4 Attachment(s)
Not the original engine, looking for correct bracket to add air conditioning compressor.
Re: Need help identifying serpentine setup.
Bracket is already there, you have a bypass pulley to the left of the tensioner
1988-`1995 brackets |
That correct started in 1988
Those are 88-89 brackets. 88-89 were made out of stamped steel. 90-95 are cast aluminum.
Thanks for all the replies. With the compressor moved to the passenger side, what condenser and manifold hose set should I use?
Thanks everyone.
